G26/644 bulb type carb
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> G26/644 bulb type carb
Page: [1]
Login
G26/644 bulb type carb - 7/14/2006 2:36:41 PM
Brian Smith
Status: offline
Just for fun I got a 644 carb to try on one of my G26's. What do I do with the primer bulb and gas hook up? Cap it off? Change it over to the metal stock type plate? Thanks. Brian
_____________________________
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
       Post #: 1
RE: G26/644 bulb type carb - 7/14/2006 4:33:24 PM
Herby 1
Status: offline
The bulb is there to pump fuel into the carb before starting, the excess comes out of the tube when the carb is full..Won't hurt anything, you can put a hose on it to keep fuel from the inside of the cowl...Nothing will come out when the engine is running..
You can't just replace it with a cover, there's a small hole leading from the edge of the chamber to the tube...You can plug the hole with a 4-40 screw if you change covers..If you don't plug the hole, fuel will leak out....
The 644 is exactly the same carb internally as the others without the bulb...
(in reply to Brian Smith)
       Post #: 2
RE: G26/644 bulb type carb - 7/14/2006 4:37:08 PM
Brian Smith
Status: offline
Thanks as usual Ralph. The G26 you converted for me is a "REAL" screamer. Starts, runs, and idles wonderful. It is by far my favorite G26. Brian Smith
quote:
ORIGINAL: RCIGN1
(in reply to Herby 1)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU3
