J_R
[QUOTE]Originally posted by FlyingZee What would y'all do if y'all saw this guy disregarding safety? You know that he would be sueing the AMA when they denied to pay for the person he injured or the cars that he damaged. Regardless of the outcome, the fact that the AMA had to defend itself would cost it a lot of money. [/QUOTE] You do not need to worry about the AMA. When you, and every other member, applied for an AMA license, you agreed to follow the Safety Code. Virtually the first line of the Safety Code states that you must follow it or there is no coverage. When you received your license, you received another copy of the Safety Code with it, and again almost every time the AMA contacts you. If he is flying in violation of the Safety Code, he has no coverage. It is cut and dry. If, after talking to him, you feel that he will continue to do what he is doing, take yourself out of the situation. If you truly believe that he is putting people or property at risk, as with low passes over people, call the police, assuming you are not a law enforcement officer. Let them do their job, and make a decision if what he is doing is unsafe. You do not have the authority to do anything yourself. The last thing in the world you want is an altercation with him. JR
