Computer power pack as a charging source
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> Computer power pack as a charging source
Page: [1]
Login
Computer power pack as a charging source - 7/15/2006 7:35:45 PM
mocars2
Status: offline
I remember reading a thread or article on using a computer power pack as a charging source, but I can't find it. I have a 200w one that is brand new but When I plug it in, it doesn't go on. How do you turn one of these on? Do you have to use a switch and if so, which wires are the one to hook up a switch to?
       Post #: 1
RE: Computer power pack as a charging source - 7/17/2006 9:32:02 PM
sukhoiflyer
Status: offline
Try http://www.rcbatteryclinic.com. I built one using this link. Basically you have to load the 5 volt side with a 25 watt 2 ohm resistor before the 12 volt side will output any power or the fan will even run.Good luck!
(in reply to mocars2)
       Post #: 2
RE: Computer power pack as a charging source - 9/5/2006 12:55:19 AM
Geoffinpdx
Status: offline
Here's another site: http://reckerclub.tripod.com/id105.html Between the two of them you should understand exactly what to do. I used a truck turn signal assembly isolation mounted to the top of the one I built instead of the resistor on the 5V side and obtained 12.02V plus a pilot light to remind me when it's on. Works well!
(in reply to sukhoiflyer)
       Post #: 3
RE: Computer power pack as a charging source - 10/6/2006 6:06:29 AM
Mike Bogh
Status: offline
i HAVE BUILT AND HAD EXELLENT sucess with the above links...4 to be exact.
I can get a near unlimited supply for zero bucks..
_____________________________
Best to you all,
Mike
In memorium
Art Grabow Sr. AKA Grnbrt..RIP mah Brother
(in reply to Geoffinpdx)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU3
