RE: Four engine model
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Four engine model
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Four engine model - 8/5/2006 4:48:30 AM
twinman
Status: offline
BillS
Saw your idea on the four engine Pheonix.
Check the picture attached. Something like that??? The plane weighs 6.5 pounds empty,,four .32's?? or LA 40's??
The nacelles can be moved in and glued closer, but the original screws for mounting will not have much to grab...Uh..If you cut into the wing..under the nacelle mount, where could not be seen, you could install blind nuts inside the wing, bolt and glue then!! Mmmm
Twinman
PS,,no, at this time building as twin, but...
Click to see fullsize image.
Click for fullsize
(in reply to BillS)
       Post #: 51
RE: Four engine model - 8/6/2006 12:32:59 AM
BillS
Status: offline
Wow! That looks exciting.
Bill
(in reply to twinman)
       Post #: 52
RE: Four engine model - 8/6/2006 3:28:21 AM
twinman
Status: offline
BillS,
I am humbled in your presence,BUT IT WAS YOUR IDEA!!! I am innocent!!
Twinman
Now where did I put Neils email??..Rats, have already glued the nacelles in the proper place, you would need to move inward and a little sanding, not much to get a good fit on the wing.
(in reply to BillS)
       Post #: 53
RE: Four engine model - 8/8/2006 2:45:44 PM
BillS
Status: offline
quote:
I am innocent!!
Well … that’s questionable.
If it doesn’t struggle to get off the ground I probably won’t know how to fly it. Maybe a brick can be found.
Bill
       Post #: 54
RE: Four engine model - 8/8/2006 7:19:45 PM
twinman
Status: offline
One brick coming up..might be a good way to practice warbirds..Getting closer on the build, but no time to post process. Like always will wait till last minute then hours catching up with build story.
Twinman
(in reply to BillS)
       Post #: 55
RE: Four engine model - 8/10/2006 6:02:06 PM
twinman
Status: offline
BillS
You happy now!!???..no, I borrowed the extra nacelles to mess with you. Tee Hee
No, it will fly as a twin!!
Twinman.
Click for fullsize
Click for fullsize
       Post #: 56
RE: Four engine model - 8/10/2006 9:47:57 PM
BillS
Status: offline
Thanks for the intriguing picture, which looks good. The twin disease is bad and unrelenting. But you already know that.
13” props? Must be using too much engine again. Assume the engines will be mounted at 9 o’clock.
With some thought about the inboard nacelle location the airplane could be a twin with option for bolt on nacelles for two more engines. As more experience is gained … ho, ho, ho.
Lets see … A .60 twin should come in at about 10# and 4 .40’s at a little over 12#.
The prop to fuselage clearance appears that it will be large. What is the center distance on the engines?
Bill
       Post #: 57
RE: Four engine model - 8/11/2006 3:33:06 AM
nchrome
Status: offline
Twinman is that a P-61 Blackwidow in the background. How soon will it be flying?
(in reply to BillS)
       Post #: 58
RE: Four engine model - 8/11/2006 4:43:20 AM
twinman
Status: offline
BillS,
The CURRENT and stock center to the fuse is now 10.5". My two cents is IF and I say IF someone were to do this. Move and glue the inboard nacelles center around 6.5", which would allow up to 12" props safely and then move the outer nacelles to a similar centerline to the inboard. My two cents, based upon the Cedar B-17..You would NOT need 40's unless something like LA's. Good .25's to .35's would work and be lighter. The prototype Ceder B-17 has magnum .32's, with inefficient three blade props and will go straight up..and that was before the new fifth engine.
Neil WILL pick up these nacelles again, but YOU asked for it!!
Tee Hee.
Disclaimer...( Too many Lawyers!!!) Cedar, to my knowledge has not tested anything like this, no have I ........Ok..Ok,,maybe someday!!
Good Luck,
Twinman
PS To nchrome on the P-61..Geeze..you guys don't miss much!!! That plane is over two years old,,can't or won't leave in the Garage in Houston in the summer. To date, around 20 flights and three engine outs..not a big deal..other than what happens to my heart rate!!!
(Mental Note)..be more careful of back ground..you would not like to have seen the picture of my bare feet in one post up at the Phoenix build that I spotted before posting...now there is a MENTAL IMAGE!!!
(in reply to BillS)
       Post #: 59
RE: Four engine model - 8/23/2006 9:23:11 PM
BillS
Status: offline
The picture is the beginning of my 4-engine project. The nacelles will consist of two parts, a wing mount and a tank and engine module. The picture shows a wing mount.
I finally solved the long idle problem. It was a tuning and glow plug issue and the sweet spot wasn’t being found. The engines will idle for ten minutes now.
Bill
Click for fullsize
       Post #: 60
RE: Four engine model - 8/23/2006 10:17:38 PM
KidEpoxy
Status: online
quote:
from twinman:
That 12in clearance sounds like 4strokes in mind, but is that much disk really needed for that red zipper? Couldnt someone go the speed route with twostrokes and hi pitch short props for narrower spacing?
_____________________________
Optional MA is part of AMA history, we can go optional AGAIN if we just say so
(in reply to BillS)
       Post #: 61
RE: Four engine model - 8/23/2006 10:35:02 PM
BillS
Status: offline
Good point. 10.5” clear would allow for 20” props. My o my what a big engine.
Bill
(in reply to KidEpoxy)
       Post #: 62
RE: Four engine model - 8/24/2006 6:28:45 AM
Wayne22
Status: offline
I'm working my way up the multi ladder...one engine at a time!!
Click for fullsize
All I ask is for a chance to prove that money can't make me happy......
(in reply to BillS)
       Post #: 63
RE: Four engine model - 8/24/2006 2:30:46 PM
awood12345
Status: offline
If you are interested in four engine aircraft read this article my dad wrote. It includes our flying routine and our set up precedures.
http://www.corsairmfc.co.uk/taming_the_big_lanc.htm
Hope this helps,
Alan
(P.S. We have loads of articles on our webpage check out the articles section some others might be useful.)
(in reply to Wayne22)
       Post #: 64
RE: Four engine model - 8/24/2006 3:04:47 PM
BillS
Status: offline
quote:
ORIGINAL: nony
Very nice.
I like three engine models but almost no one builds them. They are much easier to fly and engine out is almost a non-event.
Bill
       Post #: 65
RE: Four engine model - 12/5/2006 11:02:51 AM
