Props4ever
ON, CANADA Status: online
quote:
ORIGINAL: FliteMetal To answer your question Sammy...no, laminating the thin bare unsheeted foam is not going to be at all compariable to glassing a sheeted wing. The unidirectional cellulose within the balsa sheeted wing imparts tension and compression greater than epoxy resin and fiber glass alone. It also serves to provide a smooth base more easily leveled and sanded to resemble aluminum panels. Grain of the balsa sheeting should run from tip to root. For the greatest strength, your glass cloth should be applied on a bias. This would appear as if at roughly a 45 degree weave angle to the leading or tailing edge. The weave appears as if it were an "X" VS appearing as parallel to either the leading or tailing edge. It is easy to create a test bed so you won't end up jepordizing your investment in time and materials. Well i can't sheet now as i have already stated to glass the wing sections, so far both outer wings and top of left inner wing has parallel weave as i didn't knew it should be on 45 degree angle!. Thanks for letting me know this. As for rest of the wing that still needs to be glassed ie: right top and both lower sides, i can glass these with 45 degree angles. I can't do anything for the sections that have already been glassed. Well i suppose we will see what happens once she takes off, either it will fly fine or it will return in garbage bags..Oh well.
