Props4ever
ON, CANADA Status: online
Morning, Finally yeasterday i managed to get the right thickness of foam sheet i was looking for (4"x4'x8'), i took it to my buddy's place and we began to work, by 1030pm we started to sized out and made first block section of the fuselage, by 12am we had all the sized block sections cut out except one that some how we missed. Before we started to cut out the sized block sections, we had to cut full 4' sheet into 4 almost equal sections, 11" wide x 8' long sheets, then we laminated 3 sheets togather to form 12" thick working long block, once contact cement was dried enough to handle, then we started to cut out sized block sections to form complex countour of the fuselage profile shape. Today i will attach the all templates with toothpick to each sized block section and carve out circular shape of the fuselage, then once this process is done, i will butt join all the fuselage sections togather into one long fuselage and then block sand whole fuselage into right profile. After this process i will have nice 94" long core of Connie's fuselage. We are taking pictures as we are going along the step or stages as we are progressing, i will ask Mike to post them for me soon. Sammy
