RE: Scratch building 105" W/S Super connie L-1049 G
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Scratch building 105" W/S Super connie L-1049 G Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Scratch building 105" W/S Super connie L-1049 G - 8/6/2006 5:16:17 AM
Boomerang1
Status: offline
Aerowoof, the B-36 is 110 inch span. Your choice Sammy. But having tried both methods I would never go back to IC for this type of model. Electric power solves so many problems it cannot be ignored. - John.
_____________________________
Distributor for: Nothing! So my posts can be unbiased.
(in reply to Props4ever)
       Post #: 26
RE: Scratch building 105" W/S Super connie L-10... - 8/6/2006 8:13:19 AM
Props4ever
Status: offline
John,
I am very cofident in my choice of engines, noi doughts in my mind that i will face problems with these engines as i plan to Break them in togather at same time and also sync them before installation on the model.....
Aerowoof,
I am still waiting for the drawings or pictures of B-24s flower flaps and rudder sets ups......i pmed you twice and emails you once, please let me know whats happening and when will you help out....
Build update...
This weekend being long weekend got crapped out, i was hoping to get the foam and cut out sections of the fuselage, but source of foam was closed so now it will happened during next week or weekend. Last night i made my own formers for the rader nose section that is not on the plans...
Cheers,
Sammy
< Message edited by CONCORDEFAN -- 8/6/2006 8:48:04 AM >
Current project: Super Constellation L1049G CF-TGE: http://www.rcuniverse.com/forum/m_4538333/tm.htm
Dash 7 or Yukon..
(in reply to Boomerang1)
       Post #: 27
RE: Scratch building 105" W/S Super connie L-10... - 8/10/2006 12:26:49 PM
Props4ever
Status: offline
Morning,
Finally yeasterday i managed to get the right thickness of foam sheet i was looking for (4"x4'x8'), i took it to my buddy's place and we began to work, by 1030pm we started to sized out and made first block section of the fuselage, by 12am we had all the sized block sections cut out except one that some how we missed. Before we started to cut out the sized block sections, we had to cut full 4' sheet into 4 almost equal sections, 11" wide x 8' long sheets, then we laminated 3 sheets togather to form 12" thick working long block, once contact cement was dried enough to handle, then we started to cut out sized block sections to form complex countour of the fuselage profile shape.
Today i will attach the all templates with toothpick to each sized block section and carve out circular shape of the fuselage, then once this process is done, i will butt join all the fuselage sections togather into one long fuselage and then block sand whole fuselage into right profile. After this process i will have nice 94" long core of Connie's fuselage.
We are taking pictures as we are going along the step or stages as we are progressing, i will ask Mike to post them for me soon.
Sammy
Dash 7 or Yukon..
       Post #: 28
RE: Scratch building 105" W/S Super connie L-10... - 8/13/2006 2:47:34 AM
Props4ever
Status: offline
Important Airfoil selection question and wash out,
I like to know what sort of airfoil should be used on my model, since originla plans are for "U" contol model, its showing symetrical airfoil on it, now couple of my friends mentioned that this airfoil should be changed to either semi-symetrical or high lift airfoil. I don't have much knowledge what type to select, i want opinion and suggestions from scratch Connie moulders or guys who do giant scale stuff to advice me what to choose.
Since fuselage is all ready for wing saddle cut, i need to know this my tommarow night at latest, i will cut out center wing section core first on Monday...
Another question is about the wash out on the wings?, how much degrees will it be needed to make it stable flyer and on landings specially?...
Sammy
< Message edited by CONCORDEFAN -- 8/13/2006 2:56:08 AM >
Dash 7 or Yukon..
       Post #: 29
RE: Scratch building 105" W/S Super connie L-10... - 8/13/2006 5:38:06 PM
aerowoof
Status: offline
the airfoil shown on the plan is semi symetrical and will work fine wash out should be about -2 degrees.will have the rudder and flap imfo to you a bit later.takes awhile trying to locate plans not used for 20 years
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by aerowoof -- 8/13/2006 10:54:00 PM >
       Post #: 30
RE: Scratch building 105" W/S Super connie L-10... - 8/13/2006 11:38:52 PM
Props4ever
Status: offline
Hi Aerowoof,
Thanks for the pictures, i would still like to see the drawings for mechanisum itself for fowler flaps, rudders look easy and practical.
As for airfoil, its not the one i have been adviced to use, so we will have to work with some other type of airfoil....
Sammy
Dash 7 or Yukon..
(in reply to aerowoof)
       Post #: 31
RE: Scratch building 105" W/S Super connie L-10... - 8/13/2006 11:53:13 PM
aerowoof
Status: offline
I donot know who is advising you but that airfoil had flown fine for me at 100" span and it flew fine for others in the original kit conversions.if you want to change it the try the standard naca 2415
       Post #: 32
RE: Scratch building 105" W/S Super connie L-1049 G - 8/14/2006 12:04:36 AM
aerowoof
Status: offline
the root airfoil used in the full size is
Lockheed 1049 Constellation NACA 23018
I bet you will find that it is the same as shown on the plans you have.
Click for fullsize
< Message edited by aerowoof -- 8/14/2006 12:13:40 AM >
       Post #: 33
RE: Scratch building 105" W/S Super connie L-10... - 8/14/2006 2:11:02 PM
Props4ever
Status: offline
Last night i made 3x 1/8 ply formers to give more strength ot the center fuselage where wing will mount, i also made my first dummy wing tip fuel tank out out of four 1" thick blue foam sheets by laminating them togather, i am now going to do another one for other side and today i will decide what airfoil to use and the most likely cut the wing cores also....
< Message edited by CONCORDEFAN -- 8/16/2006 5:00:40 AM >
Dash 7 or Yukon..
       Post #: 34
RE: Scratch building 105" W/S Super connie L-10... - 8/15/2006 12:47:48 AM
Props4ever
Status: offline
Hi,
I have decided to use NACA 2318 airfoil for the root and NACA 4412 for the tip. My plans shows its NACA 2318 so i am keeping that but changed to NACA 4412 for the tip due to its very high lift capabalities. This tip airfoil has very high lift capability w/o washout but even with 2 degrees of washout it still gains alot of lift, so i don't think i can go wrong with it.
Dash 7 or Yukon..
       Post #: 35
RE: Scratch building 105" W/S Super connie L-10... - 8/16/2006 5:06:31 AM
Props4ever
Status: offline
Today i made nose section of the Connie and fixed up the crooked tail section. This basically took whole evening as there were alot of care given to nose and aft fuselage sections. Now since the fuselage is basically done, my next step is to make new templates for the root wing cord and attach against the craddle of center fuselage section and cut out the wing saddle in the fuselage. Carl told me to add 4 degrees of incidence to the wing...so i will do this by using my incidence meter....
< Message edited by CONCORDEFAN -- 8/16/2006 5:08:04 AM >
Dash 7 or Yukon..
       Post #: 36
RE: Scratch building 105" W/S Super connie L-10... - 8/16/2006 12:38:31 PM
HalH
Status: offline
Lets see some pictures !
       Post #: 37
RE: Scratch building 105" W/S Super connie L-10... - 8/16/2006 4:10:34 PM
Props4ever
Status: offline
Hi Guys,
I know everybody is eager to see the pictures including myself, but i haven't got them as yet from my buddy, as soon as i get them i'll post them here....
Sammy
< Message edited by CONCORDEFAN -- 8/16/2006 4:18:28 PM >
Dash 7 or Yukon..
(in reply to HalH)
       Post #: 38
RE: Scratch building 105" W/S Super connie L-10... - 8/16/2006 4:46:11 PM
