Props4ever
ON, CANADA Status: online
Yet another milestone came in mail yesterday.[/b] I recieved my nose gear assembly from my builder friend, upon opening the box, i was thrilled and when i lfted it out of the box, man it didn't weight much atall!!, all work was done according to my specs and boy what a awesome piece of machine work this gear is. I took sometime to figure out how it operated and now i am getting comfortable with it's operation. Once i had it, my adralin started to kick in and i went on with it to my building room where S Connie is, started to fiddle with installing it in the nose gear bay, well as i thought, i had to trim down the former where rails would have been glued on, once this was done, i had to take out some foam from under the tri angular bay door opening and then whole assembly just slided into the bay nicely. Gear had to be folded to do this as there was no way i could have slided this assembly unfolded in the bay. I still have to open up sides of the gear bay by 1/4" on both sides and then make and install aircraft grade ply side walls there and drill holes in the sides of frame to screw it into he side ply walls. Original former is now providing base support for the assembly. Once this was installed, it took like 2-3 hrs to do this but afterwards i just had to assemble the model once again to see it under the weight of the plane. I am happy to say it all went very well. Suspension is pretty good, not too hard nor to soft, just right amount of spring tention. Fully extended length of strut is 1/4" longer then should have been but i can extend the bay further back at this time. So far it's looking beautiful on the model, WOW!!! Cheers...
< Message edited by Props4ever -- 7/9/2008 8:03:07 AM >
