Props4ever
ON, CANADA Status: offline
quote:
ORIGINAL: razorback11 CONCORDEFAN, Four stroke engines are always a wise choice for multi-engine projects because they tend to be more reliable than the two strokes (arguably). The Magnum .52 or OS .52 4-Strokes would be good choices as opposed to .40 size 2-strokes. If you went with something like the OS .70 4-Strokes, you would have plenty of power and they are very dependable but you may be getting into some weight issues again. Razorback11 Razorback, Magnum or OS 52 sounds preety good choice, plus due to huge tri tails i am sure i will have concern bring tail heavy too, so by moving firewall 1/2" forward and making slighlty longer cowls with 4 stokers i am sure it will compensate for the weigh issue, but will see once its all done. Last till now i coulden't sleep so i started to to make flaps bays on both wings, so far i only got right bay cut out, i used my favorite Shawarma slicing methord to make this bay , i will do left one tonight or towwarow....I will post picture soon.
