Darrell B.
AR, USA Status: offline
Mike, First of all, Yes the reading of 8.4 between post 5/6 is correct. Here is what I can deduce from the readings. I think that the wires for post 4 and 5 are both soldered to the same connector lug. Who ever was doing the soldering probably atached the wire for the fifth pin on the wrong side of the cell, thus making them basically the same reading which I have The reason that I say this is because when I took a reading between posts 1 and 3 I also came up with a reading of 8.4v. I aslo checked the voltage between posts 3 and 5 and found a little less than 4 volts. I don't see any distortion in any of the cells, and the entire pack voltage is a very acurate 21 volts at full charge. I flew this pack two days ago, before I received my balancers, and my CC 110 controller reported 10 cells when I first powered it up. I'm using the two 5s3p packs in seried. I hope that this helps. Darrell
< Message edited by Darrell B. -- 7/25/2006 11:02:35 PM >
