WSN T34 CONVERSION QUESTIONS!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> WSN T34 CONVERSION QUESTIONS!!
Page: [1]
Login
WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 9:13:34 PM
FFR2608
Status: offline
I am considering a conversion on this model. How are the tracks and gearboxes?
Weak or OK with some care taken while driving?
I can handle the scratch building work but want to be sure the driveline would be up to the task. I plan on using a dual ESC setup and my own electronics for the most part. Will the metal HL boxes fit in with some effort? Aftermarket tracks available? Any info you have will be much appreciated. After building the 1117, Im hooked. Just dont want to drop the cash for Tamiya right now.
DH
       Post #: 1
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 9:33:04 PM
Plastic scouser
Status: offline
here is a link for tracks and conversion sets for the T34
http://www.tankzone.co.uk/cart/tz_t34.htm
hope this helps
cheers Ian
(in reply to FFR2608)
       Post #: 2
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 9:50:13 PM
ksoc
Status: offline
Be sure to check out this site for more info. It is dedicated to RC to Bandai and WSN T34s
http://groups.yahoo.com/group/BigBandaiTanks/
Kevin O'C
<S.C.A.T>
_____________________________
Kevin O''C <S.C.A.T> www.socalareatankers.com • Tamiya-Sherman/Tiger/Pershing/Kubelwagen • HL-Tiger, Panzer III
(in reply to Plastic scouser)
       Post #: 3
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 10:15:28 PM
icecreamslick
Status: offline
You will also want to have a look at this, if you haven't already:
http://www.rctc.co.nz/russian_t34_upgrade.htm
Jason
"I find television very educating. Every time somebody turns on the set, I go into the other room and read a book."
       Post #: 4
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 10:29:13 PM
FFR2608
Status: offline
Thanks guys, I have seen these but they lend no information on the track or gearbox durability. Anone else have some input? It HAS been an entire hour since I posted this.........LOL.
DH
(in reply to icecreamslick)
       Post #: 5
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 11:18:46 PM
ksoc
Status: offline
Contact Ethan at DAK - Desert Armor Korps - He is wrapping a T34/76 conversion. He not only is updating to a Tamiya Battle system, but took backdated the entire upper tank to a T34/76 by combining the WSN kit with a static kit. Read through and he does talk about the gearboxes. An e-mail should clear up any other question you have.
www.desertarmor.com General Page
http://web.mac.com/ethandunsford/iWeb/DAK2/T34-76%20Project.html T34 Page
Kevin O'C
<S.C.A.T.>
       Post #: 6
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 11:19:50 PM
ksoc
Status: offline
Sorry it too SO long.........
(in reply to ksoc)
       Post #: 7
RE: WSN T34 CONVERSION QUESTIONS!! - 7/26/2006 11:51:17 PM
Panther F
Status: offline
Myself and another member in our tank group have done the conversion using the stock gears that came with the tank. With some reasonable driving around a battlefield that is inside (no rocks, dirt, etc.) and you should be fine. I have about 3 meetings on my T34 with about 5 or 6 battles per meeting and it still hasn't let me down. Use some 280 motors replacing the stock units and the tank is a blast!
Of course, don't expect the durability of a Tamiya gearbox.
Jeff
HL StuG III, Tamiya: M4 Sherman, M4A1E8 Sherman, Sturmtiger, T-34/85 and an M26A1 Pershing
       Post #: 8
RE: WSN T34 CONVERSION QUESTIONS!! - 7/27/2006 1:24:24 AM
sownare
Status: offline
The plastic tracks are great. They hold up very well and are plenty strong.
(in reply to Panther F)
       Post #: 9
RE: WSN T34 CONVERSION QUESTIONS!! - 7/27/2006 1:31:23 AM
TANKDUEL
Status: offline
There's some pics here of metal T34 replacement gears and tracks
http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=de_en&trurl=http%3a%2f%2fwww.rcmm.de%2fwbb2%2fznews.php%3faction%3dshow%26znewsid%3d41
but they don't seem to be listed on the Tamtoys site
(in reply to sownare)
       Post #: 10
RE: WSN T34 CONVERSION QUESTIONS!! - 7/27/2006 1:49:33 AM
Panther F
Status: offline
WOW! I'd like to try a set of those!
Jeff
(in reply to TANKDUEL)
       Post #: 11
RE: WSN T34 CONVERSION QUESTIONS!! - 7/27/2006 2:14:26 AM
James S.
Status: offline
I have a T34 that is now converted to use Pershing Gearboxes BUT before that I used the 280 with standard gearboxes... the problem was striping the final drive gears... they did not last long at all (less then 5 min in one case) . ... I would not mind trying those metal gears in one to see how they hold up. could make converting the T34 to Full Option MUCH MUCH less expensive and less time consuming. Those tracks look awesome
Regards,
J
       Post #: 12
RE: WSN T34 CONVERSION QUESTIONS!! - 7/27/2006 2:24:35 AM
TANKDUEL
Status: offline
Here's a 'how to' on the T34 metal gears
http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=de_en&trurl=http%3a%2f%2fwww.rc-mm.de%2fwbb2%2fthread.php%3fthreadid%3d1306
(in reply to James S.)
       Post #: 13
RE: WSN T34 CONVERSION QUESTIONS!! - 7/28/2006 4:41:49 PM
FFR2608
Status: offline
Will the HL gearboxes fit in the T34 with minor mods or are they just too big?
Dh
       Post #: 14
RE: WSN T34 CONVERSION QUESTIONS!! - 7/28/2006 11:46:01 PM
schutzstaffel
Status: offline
check this link , might interest you , you may have to use a translator ...
http://www.rc-panzerketten-forum.com/wbb2/thread.php?threadid=2305&threadview=0&hilight=&hilightuser=0&sid=729c019453c33f899832a369e84498ce&page=1
       Post #: 15
RE: WSN T34 CONVERSION QUESTIONS!! - 8/1/2006 3:57:38 PM
FFR2608
Status: offline
Anyone tried the metal HL gearbox in the 34? I have seen the Pershing box squeezed in there which I believe is the same as the Tam. tiger. If the HL is a direct copy of that, maybe the Hl gearbox will fit. Anyone follow that?
DH
(in reply to schutzstaffel)
