leadgofer
Joined: 1/1/2003 From: Jacksonville, IL, USA Status: offline
My P-51 is on its 4th season ( probably has 80 flights ). I have a G-62 with monocote covering. Weighs 24.5 lbs. Has been clocked @ 105 MPH. Mine balanced perfectly with the G-62, muffler, spring starter, vibration mount, so keep the tail light or you'll have to add nose weight. I also use a 2400 mAh battery. You'll have to cut at least a 1/2" off the gear covers if you fly off of grass. I use full flaps to land, ( all throws are as reccommended in the instructions ). [image][/image]
