OVER WORKED
Joined: 2/11/2003 From: Deer Park, NY, USA Status: offline
At 12,000 RPM Turk's engine with a 12/5 APC is making about 1.1 horsepower according to my calculator, and thats on NO NITRO fuel at 200 METERS and 90 Degrees, thats a density altitude of about 4.000 feet making around 7.5 pounds of thrust. And he's using an exhaust deflector, something well known for not boosting power. At 13,500 with a 12/4 APC, XJet is making 1.25 hp and around 7.8 pounds of thrust. don't know about altitude (so I used 1,000 feet} or nitro, but 10% will boost RPM in most small engines about 700-1,000 over FAI fuel. To turn a 12/5 at 13,500 you would need to make almost 1.6 HP, and would generate about 9.5 pounds of thrust {you are now in the thrust numbers of most 70+ size engines}. In a 50 size engine that would be a very impressive number without a pipe and some high nitro, and even then I would be impressed. Seems the word is out on the SK line of engines, We sold almost 300 in one month a new record for us.
_____________________________
Ray Nano Kangke/ Super Kraft/ Brison, Tech support/Design team
