Ed_Moorman
FL, USA Status: offline
The 15-6 as a minimun size prop is what I gleaned from the original thread on SK and from Ray Nano. I bought my first .91 after reading the thread here and from the great comments, especially from Turk1 on his 50s. After flying my first .91, I ordered a second one and a .52 (they call it a 50). I had been flying a lot of OS with several other brands, too. Except for the dragging carb barrel, which I fixed with a file on the end of the groove, I can say nothing bad about the brand. I have been thinking about gettng another .52 to use on a twin, and normally I never use anything but OS because of the reliability factors. And believe me, I have tried others. My SKs have been super reliable, 1-flip starters, and very economical to run. They aren't screamers, but I have other engines for that. In my opinion, the carb design is excellent. The manufacturing is a little off on some of them and I am sure Kangke is working to get that fixed. It has an excellent idle, the mid range is right on and the top end is good. Much, much better than Magnum, for example. I should probably run my OS .46AX, my OS .55AX and my SK 50 all on a 12-5 and compare. Maybe also do an 11-7 and a 12-6. The 55 seems to run well on the 11-7.
_____________________________
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156 R/C Report Magazine, Fun Aerobatics Column
