XJet
Joined: 3/31/2003 From: Tokoroa, NEW ZEALAND Status: offline
quote:
ORIGINAL: prgonzalez Another probability is you might have an air leak in the carb. Try re-seating the carb body into the engine. Also, make sure the barrel closes completely when you kill the engine. Yes, it might pay to put some red silicone around the bolt that holds the carby on. I've seen them suck air through there and, because it's below the O-ring on the base of the carby, that air goes straight into the crankcase. However, *my* SK50 is noticeably more sensitive to fuel-head than my TT46Pros.
_____________________________
When I'm not here, I'm at RCModelReviews
