RE: E-FLITE BLADE CP PRO
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Blade CP Pro
  • 5 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: E-FLITE BLADE CP PRO
    Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
    Login
    RE: E-FLITE BLADE CP PRO - 8/31/2006 11:06:29 PM
    Commander_Bob
    Status: offline
    I think my Cpp has sticky collective pitch becase no wind is being blown even at high head speeds. Does any one know of a fix to sticky pitch?
    thanks
    _____________________________
    Taking it one day at a time.
    (in reply to orlbuzz)
           Post #: 76
    RE: E-FLITE BLADE CP PRO - 9/1/2006 6:23:25 AM
    Commander_Bob
    Status: offline
    Man 2nd day Flying EVER and I've hovered in one place stable for around 10-15 seconds. It;s becoming eayser each battry. Only crash so far was when it was going forward and I pushed forward insead of back and it ran into a storage box. The only damage thugh is a small chip in the back of the blade near the blade grip and the covering is cracked.
    Man I love flying this thing I'll probably leave my gradge soon.
           Post #: 77
    RE: E-FLITE BLADE CP PRO - 9/1/2006 6:29:04 AM
    Greenhorn Heli Flyer
    Status: offline
    quote:
    ORIGINAL: Commander_Bob
    That chip is from the blade hitting the head. To repair the blades I use small strips of thin packing tape. You want to keep the surfaces smooth for smooth airflow and maximum lift. Do you have a simulator?
    (in reply to Commander_Bob)
           Post #: 78
    RE: E-FLITE BLADE CP PRO - 9/1/2006 1:10:35 PM
    Psikelly
    Status: offline
    Try a little oil for sticky parts. I use something from radio hack that has teflon bits in it. It comes in a small pen style applicator with a needle type tip. Works very nice.
    Also check to make sure your blade gripsare nice and free to move, disconnect linkages and try twisting them. If theyre too tight you may need to remove a shim.
    Also check the main hub to be sure it isnt bent. Any slight bend at all and it becomes sticky and wont allow pitch changes. When you twist the blade grips with everything disconnected youll feel it sticking.
    If you cant tell the difference between sticky blade grips or sticky main hub, then take hold of the piece that slides on the main hub and slide it by hand. If you feel ANY stick at all replace it.
    You may also want to check the spindle to be sure its straight. Take off the lade grips and roll the spindle on something real flat like glass and look for a bad roll.
    NO I did not just crash!! Im making it flop around on the ground like that on purpose. Its a new stunt.
    (in reply to Greenhorn Heli Flyer)
           Post #: 79
    RE: E-FLITE BLADE CP PRO - 9/1/2006 6:32:02 PM
    supac
    Status: offline
    What is the Heading GYRO for? by the way I am a beginner and have not taken the BCCP out of the box yet. I have heard that upgrading the Gyro makes it easier to fly the BCPP is this true?
    (in reply to Psikelly)
           Post #: 80
    RE: E-FLITE BLADE CP PRO - 9/2/2006 2:09:12 AM
    Psikelly
    Status: offline
    A head holding gyro is supposed to keep the tail locked straight in place. Which Im TOLD is very important for stunt flying. So theres no need to keep correcting tail drift, Cuz there is none.
    Now this is what Im told. I have a new G90 HH gyro but Im still getting things setup and repaired so I cant say what it actually behaves like yet. I also only hover and slow FF right now, no stunt flying.
    (in reply to supac)
           Post #: 81
    RE: E-FLITE BLADE CP PRO - 9/2/2006 2:57:51 AM
    manny86314
    Status: offline
    Ive now had my cp pro for about 3 weeks and just did upgrades to it last week with 4100 brushless motor, carbon fiber blades, 25 amp ESC, and the heading lock gyro I have to say it's a nice upgrade from previous heli (mini dragonfly).It flies and it hovers like a champ,
    as for 3d flying im still trying to perfect on G3 ive only been flying for a little over a year, next thing is to install a 10 amp ESC for the brushless feigao tail motor. You cant even notice 10 mph wind =)))
           Post #: 82
    RE: E-FLITE BLADE CP PRO - 9/2/2006 4:34:52 AM
    Commander_Bob
    Status: offline
    quote:
    ORIGINAL: Greenhorn Heli Flyer
    I don't have a simulator and I used some super glue for the chip and scotch tape for cover it. It worked like it was never hit, but today I hit a glass bottle and the end of the blade got smashed so I repaired it and spun it up but it was shaking a lot so I'm going to get new blades tomaro. I was wondering what blades to get (stock, Carbon fiber, or plastie [I don't think my LHS carries plastie]).
    Thanks for all of your help
           Post #: 83
    RE: E-FLITE BLADE CP PRO - 9/2/2006 8:06:43 PM
    shag555
    Status: offline
    I bought a BCPP after a buddy let me fly his BCX for a couple of seconds. Been flying Planes now for 6 years, and always wanted a heli, so I took the plunge. Been flying outside and in the garage during eve's and rainy days. Have the hover down tail in, working on sides in.
    I stuck the plastic blades on, added one set of flybar weights to slow it down a little, and also followed the 5 series of videos that were linked on a thread here somewhere. The vids made a ton of difference in understanding how this thing works, and how to better set it up.
    I get 10 min flights out of the 850 mAh pack, I'm sticking on a set of flat bottom wood blades to see if my flight times improve.
    I've smashed the tail boom to "boom strike" now 3 times, mainly due to fear (slamming down on the grass & concrete). I went the midwest carbon fiber route, as it's only $5 for two pieces of tail boom material. The last tail boom piece I had got hit, and I had to CA it back together, then for torsional strength, I lightly wrapped and crossed the entire boom with thread and CA'd it in place. It'll work until I can get to the store and buy another 2 ft length.
    I'm a big time penny pincher. I've built and re-built many planes. Just wondering if anyone has built their own blades for these helis. They dont look overly complicated, maybe just that you need some hard balsa???
    MPB
    MPB
           Post #: 84
    RE: E-FLITE BLADE CP PRO - 9/2/2006 8:13:23 PM
    shag555
    Status: offline
    One other cheapO trick I did for training gear was to buy 0.080 inch X 2 ft carbon fiber, zip tie them to the landing skids (each outside corner), then CA 4 ping pong balls to the ends of the carbon fiber rods (completely through the balls). The build costs ~ $4 compared to the $10 Eflight gear.
    MPB
    MPB
    (in reply to shag555)
           Post #: 85
    RE: E-FLITE BLADE CP PRO - 9/3/2006 4:19:32 AM
    Commander_Bob
    Status: offline
    I got new blades today and I can now hold a steady hover.
    I got to get more stick time.
           Post #: 86
    RE: E-FLITE BLADE CP PRO - 9/3/2006 1:39:23 PM
    shag555
    Status: offline
    How much more duration (flight time) would a brushless motor make??? I've got a Himaxx 2025 with Castle Creations 25 amp ESC lying around from Electric plane days that would fit nicely with this heli. The conversion doesn't look at all complicated. I see others that say the Blade is a completely different anmial though.
    MPB
    MPB
           Post #: 87
    RE: E-FLITE BLADE CP PRO - 9/3/2006 1:41:19 PM
    shag555
    Status: offline
    One other item worth noting... I adjusted the tracking (as you can imagine it was out after a chicken dance). My flight times improved to 13 minutes from 10 minutes!
    MPB
    MPB
           Post #: 88
