RE: E-FLITE BLADE CP PRO
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Blade CP Pro
  • 5 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: E-FLITE BLADE CP PRO
    Page: <<   < prev  66 67 68 69 70 71 72 73 74 [75]
    Login
    RE: E-FLITE BLADE CP PRO - 1/24/2008 8:02:26 AM
    krysohmyz
    Status: offline
    I don't know if my option of Optic 6 wil help you, but anyway...
    Normal:
    PC , ThC
    1: 25 , 0
    2: 40 , 35
    3: 60 , 65
    4: 84 , 85
    5: 100 , 100
    Idle 1:
    1: 0 , 100
    2: 27 , 95
    3: 55 , 80
    4: 82 , 95
    5: 100 , 100
    Idle 2:
    1: 0 , 100
    2: 25 , 100
    3: 50 , 100
    4: 75 , 100
    5: 100 , 100
    (in reply to Pattern_is_Fun)
           Post #: 1851
    RE: E-FLITE BLADE CP PRO - 1/24/2008 5:25:00 PM
    Pattern_is_Fun
    Status: offline
    Thanks, not sure these relate to my numbers, but I have it close.
    sc
    (in reply to krysohmyz)
           Post #: 1852
    RE: E-FLITE BLADE CP PRO - 1/24/2008 10:41:03 PM
    onad
    Status: offline
    Anyone have input on a decent performance and priced gyro for the CP Pro?
    Tx, Onad
           Post #: 1853
    RE: E-FLITE BLADE CP PRO - 1/25/2008 3:53:22 AM
    gene465
    Status: offline
    Okay I replaced my stock blade grips when they broke with the Mico-heli aluminum ones. Now I can't get any lift whether I have 0 pitch or positive pitch, yet if I put the idle on, there is lift what gives? Did I put them on wrong somehow? Now when I move the right stick forward like I want to go fwd then it wants to lift. I set everything up like B-Davidson's guilde with the swashplate and pitch and everything but I get no lift. I double checked the radio settings to make sure I did not somehow change something on the setting but everything checks out. I am new to helo's so I don't know a whole lot here. Been trying to read the CP Pro thread but only have gotten so far. Anyone know? Thanks Gene
    _____________________________
    T-Rex 450SE, 450SA, Sea Fury 400, P-47D, Lancair ES, Ultra Mini Stick, Taylorcraft 450, Traxxas Revo
    (in reply to onad)
           Post #: 1854
    RE: E-FLITE BLADE CP PRO - 1/25/2008 9:43:13 AM
    wake133
    Status: offline
    mine keeps stripping servo gears....WHY????
    (in reply to Remyrw)
           Post #: 1855
    RE: E-FLITE BLADE CP PRO - 3/4/2008 11:07:09 PM
    bladeCX1464
    Status: offline
    hey all. i recently got back into helos. i have bcpp and i am not sure it its true but i heard that if you use the eflite gyro with the brushless setup that they will interfere. is that true?
    (in reply to wake133)
           Post #: 1856
    RE: E-FLITE BLADE CP PRO - 3/24/2008 11:21:17 PM
    bladeCX1464
    Status: offline
    okay i need alot of help. my 3 in 1 blinks from red to green and i have checked everything? any tips?
    (in reply to bladeCX1464)
           Post #: 1857
    RE: E-FLITE BLADE CP PRO - 3/25/2008 12:08:43 AM
    krysohmyz
    Status: offline
    I don't have blade anymore, but as I remember (I hope it's true, because I can't check it now...) red and green blinking means Rx isn't recieving signal (Tx switched off, Idle up on (plus Tx can't transmit when switched on while idle is up), damaged antenna,...)
    Good luck
    Kryso
           Post #: 1858
    RE: E-FLITE BLADE CP PRO - 4/19/2008 5:10:26 AM
    bladeCX1464
    Status: offline
    okay im doing a project for school that requires a camera mounted on my bcpp. i have added the payload up to be around 8oz. with the blade handle that for a brief 3-5 minutes at most?
           Post #: 1859
    RE: E-FLITE BLADE CP PRO - 4/21/2008 3:01:12 AM
    rjd9779
    Status: offline
    [image][/image] Does anyone know if I can upgrde my lipo batt. to get more flight time? If so, what size should i go up to for the cp pro? thanks...Rich
           Post #: 1860
    RE: E-FLITE BLADE CP PRO - 4/21/2008 2:20:34 PM
    Carljw
    Status: offline
    I got a Mega Power 15c 11.1v 1350mah at my local hobby Town for around 29.00 for my cpp and get a few more minutes time with it . Its a little bigger but fits ok .
    Carl
    (in reply to rjd9779)
           Post #: 1861
    RE: E-FLITE BLADE CP PRO - 4/23/2008 1:27:28 AM
    rjd9779
    Status: offline
    ok i'll try that one thanks
    (in reply to Carljw)
           Post #: 1862
    RE: E-FLITE BLADE CP PRO - 4/23/2008 12:54:09 PM
    derek2005
    Status: offline
    I am having a glitching issue with my BCPP. For some reason, it seems worse when I move cyclic to the right, however it is not isolated to this movement. I assume this is a reciever issue or a transmitter issue??? Any suggestions.
    Happy Flying
           Post #: 1863
    RE: E-FLITE BLADE CP PRO - 4/27/2008 7:42:49 AM
    soccerball
    Status: offline
    Hey i got my blade cp pro a few days ago but now it doesnt want to turn off so i have to unplug the battery. does anyone know why?
    (in reply to robmoney)
           Post #: 1864
    RE: E-FLITE BLADE CP PRO - 4/27/2008 5:47:15 PM
