ct420
TX, USA Status: offline
Did you crash it at all? Even slightly? If a rotor blade struck anything, then it is possible that you just didn't get the throttle pulled back in time, and the overload took out the mosfet. Of course, there are many other possibilities. It is also possible that the mosfet went bad due to harmonic vibration (resonance). If your rotor is badly unbalanced, it will create a resonance vibration at speed, which will KILL many electronic components. Or, it could be that the motor or wires or something on that channel has a problem, causing it to draw too much juice. It is possible that the mosfet simply was defective when installed. It is not too uncommon for new components to quickly go bad. Especially high current components like these mosfets. If there is any tiny little defect when it is manufactured, it will fail very quickly if it works at all. I could go on, but I'll stop, 'cause you get the idea. Do you have an amp meter? If so, try measuring the current draw of each motor at full speed, and see if one seems a lot higher than the other. Also, use an ohm meter and visually inspect the wires and plugs to make sure there are no shorts anywhere. This is where I would start. Of course, you are going to have to get the 4 in 1 fixed again, I'm afraid.
