Texan
TX, USA Status: online
quote:
ORIGINAL: GalenB quote:
ORIGINAL: Texan On my Cermark Pitts, I'm running (4) HS 525bb on ailerons and (2) HS 6635hb digitals on rudder and elevator at 6V. I don't understand why the 5475's wouldn't work on ailerons. Each surface is rather small on a biplane with four ailerons. My thoughts exactly! Each aileron, or elevator half, is rather small by itself. I think 6 5475 servos on elevators and ailerons should be enough for a slightly larger than 12 lb model. I understand Mike's reluctance to endorse this setup (liability, Lawyers, etc), but that doesn't change the fact that in this case these servos are IMHO large enough at 6v for the job... Are you planning to use one servo per elevator half? The stock Cermark Pitts uses a torque rod to join the elevator halves. If you use a pull-pull setup for the rudder, then the right side rudder servo location could be used to drive the right elevator half.
