RE: Its Bobcat nice
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Its Bobcat nice
Page: <<   < prev  12 13 14 15 16 17 18 19 [20] 21   next >   >>
Login
RE: Its Bobcat nice - 1/9/2008 6:47:47 PM
opjose
Status: offline
quote:
ORIGINAL: z06kal
How bad was your negative incidence? Ie difference in inches between mains and nose?
I never really meaured, and since the gear differ in length the only way to get something accurate would be with an incidence meter.
I believe it was about -2 degrees or so, though.
Now I have about 2-3 degrees of positive incidence.
Change your incidence. Make it positive.
While you may want to avoid making the change, you'll be glad you did.
< Message edited by opjose -- 1/9/2008 6:50:05 PM >
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to z06kal)
       Post #: 476
RE: Its Bobcat nice - 1/9/2008 7:16:01 PM
AGR413
Status: offline
I must have a different plane lol I don't touch the elevator and at speed mine will lift up into the ground effect and I then apply elevator. Go figgur?
< Message edited by AGR413 -- 1/9/2008 7:23:29 PM >
If you are flying, life is good.
(in reply to opjose)
       Post #: 477
RE: Its Bobcat nice - 1/9/2008 7:20:00 PM
opjose
Status: offline
quote:
ORIGINAL: AGR413
I must have a different plane lol I don't touch the elevator and at speed mine will lift up into the ground effect and I than apply elevator. Go figgur?
At what incidence?
(in reply to AGR413)
       Post #: 478
RE: Its Bobcat nice - 1/9/2008 7:22:56 PM
AGR413
Status: offline
Positive nose incidence of course, I was thinking of FBD's reply when I typed that.
       Post #: 479
RE: Its Bobcat nice - 1/9/2008 7:25:03 PM
Flyboy Dave
Status: offline
....wierd. Even though I have mine is nose high and balanced, and I still must pull lots
of "up" to get it airborne.
Most of them need 1/8" "up" trim in the elevator as well for level flight. So maybe the
wing has negative incidence relative to the horiz. stab. The nose high "angle of attack"
is off-setting the negative incidence in the wing ???
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
       Post #: 480
RE: Its Bobcat nice - 1/9/2008 7:30:32 PM
Flyboy Dave
Status: offline
quote:
ORIGINAL: AGR413
....you're talking about the angle of attack, with a nose high attitude.
Revver Bro #4.
       Post #: 481
RE: Its Bobcat nice - 1/9/2008 7:43:16 PM
opjose
Status: offline
Mine will fly level with the trailing edge of the elevator, level with the top trailing edge of the horizontal stabilizer... or just beyond that.
However relative to the fuse it appears that I have some positive incidence to the wing.
(in reply to Flyboy Dave)
       Post #: 482
RE: Its Bobcat nice - 1/9/2008 8:25:20 PM
AGR413
Status: offline
quote:
ORIGINAL: Flyboy Dave
quote:
ORIGINAL: AGR413
Yes professor FBD postive angle of attack with the nose gear fully extended.
My elevator is within 1/16-1/8 of being level with the top of the elevator at neutral. Balance is at 10.3-10.5 aft of leading edge meeting fuselage measured right side up (not upside down). I know I know. Mine is right on the margin for CG, if it gets started going up it wants to keep going up but displays no other bad behavior which is no big deal because this plane should be "flown" everywhere it goes anyway. There may be a motor incidence issue in there somewhere to but I'm not going to go digging it flies just fine. However those of you that came up with the spoileron solution my hat is off to you. I have many many flights now with the spoilerons and I am one happy camper. No more "O GOD ITS TIME TO LAND THIS BEAST" I on the switch just before I reach the end of the runway and flare just before touchdown (looks just like I know what I am doing, even though I don't shhhhhhh)
       Post #: 483
RE: Its Bobcat nice - 1/9/2008 8:31:35 PM
Flyboy Dave
Status: offline
Maybe they all vary....I'll check mine and see where it's at.
Revver Bro #4.
       Post #: 484
RE: Its Bobcat nice - 1/9/2008 8:36:35 PM
AGR413
Status: offline
I was waiting for your reply, I think the mounting of the booms (which affects elevator incidence) is very subjective on this plane. The tips of my booms don't sit flush on the wing (very slight gap) but the rest of the boom sits snug on the wing, this seemed intuitively more correct to me. Maybe this plays a role as well. The relocation of your landing gear may (may) play a role as well?
       Post #: 485
RE: Its Bobcat nice - 1/9/2008 8:58:16 PM
opjose
Status: offline
quote:
ORIGINAL: AGR413
That succintly describes landing the plane w/o spoilerons!
       Post #: 486
RE: Its Bobcat nice - 1/9/2008 10:04:21 PM
z06kal
Status: offline
Okay I redid my retracts. Unfortunately I had to cut a slot in the nose wheel wheel well for the wheel to go down further. Oh welp more cooling for the 3.5 pounds of batteries LOL. Right now my nose wheel is about 3/4" longer than my mains. Is this the ammount of up incididence I want or more or less?
< Message edited by z06kal -- 1/9/2008 10:05:01 PM >
       Post #: 487
RE: Its Bobcat nice - 1/9/2008 10:25:14 PM
opjose
Status: offline
As long as the wings sit either level with the ground or the leading edge is higher than the trailing edge you'll do fine.
Remember that this is along the wing chord.
Add spoilerons too! You need them with this plane.
       Post #: 488
RE: Its Bobcat nice - 2/12/2008 4:25:33 AM
bettungesvik
Status: offline
Hey guys, I have an OS .75 I was thinking about throwing on my Bobcat. What do you think?
       Post #: 489
