WW2 Ace
MI, USA Status: offline
quote:
ORIGINAL: sailing1 WW2 ACE. I am about at the same point as you with my Extra. With the exception of battery placement I look to be set up very much the way you are. Heck -- I used your build as much of my example. I probably will not be able to finish mine this weekend as I will be off racing sailboats. I am however still concerned about where to place my antenna wire. I noticed you ran your aft servo wires down the middle of the plane. Where do you plan on running the antenna. Also, and I know this has been beat around a little, is there any concern about running the short carbon fiber throttle linkages for the throttle and choke? I have an amplified choke that I can put on the throttle servo but think that is serious overkill. I have just heard rumors about carbon fiber conducting electricity and not to use it for throttle servos (I will use a plastic connector of some type on the carb arm). Thanks in advance. First let me say I'm honored your (or anyone for that matter) are using my build as a guideline , I just hope I haven't started you or anyone with bad habits ! This is only my second GS build and I still have a lot to learn. As to your questions, I plan to run the antenna wire down through a hole in the fuse and down the center on the outside of the plane as I did on my Edge. I had the same servo wire / antenna arrangement on the Edge and experienced no issues. In fact, my radio range checked at over 400' with the engine running and off with not so much as a twitch. Abo |
