RE: Redesigned 28% Extra 300 Build / Questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Redesigned 28% Extra 300 Build / Questions Page: <<   < prev  10 11 12 13 14 [15] 16 17 18 19   next >   >>
Login
RE: Redesigned 28% Extra 300 Build / Ques... - 10/11/2006 5:18:42 AM
Tired Old Man
Status: offline
Depending on the surface deflections and airspeed it should snap out when it's pulled hard. An aircraft can stall at any airspeed and at any attitude. FAA Student Pilot training 101. Models are no different, just smaller with more power. Controllability is a matter of correctly making stick inputs for the condition of flight, not corner banging.
OTOH, if you're setting up for IMAC and depending on being able to hammer the sticks to the stops to perform an effective snap, then a reduction in surface deflection is in order. I am definately not one that believes in this method of performing a maneuver.
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to cyoung450)
       Post #: 351
RE: Redesigned 28% Extra 300 Build / Ques... - 10/11/2006 12:42:49 PM
dhawks
Status: offline
I've been looking at this plane for awhile and it looks like a candidate for a 3W-56 twin. Can someone give me the cowl dimensions? I'm interested to know if the twin will fit in the cowl.
Dennis
(in reply to Tired Old Man)
       Post #: 352
RE: Redesigned 28% Extra 300 Build / Que... - 10/11/2006 3:11:14 PM
rctom
Status: offline
The cowl is 10.25" wide at the F1 former. Farther forward where the plug caps would be it narrows very slightly, it looks like it's about 9.75" to 10" at that point.
The 3w56 is 262mm plug cap to plug cap, which is 10.3" approx. It looks like the left side plug cap will protrude from the cowl a little.
TF
(in reply to dhawks)
       Post #: 353
RE: Redesigned 28% Extra 300 Build / Que... - 10/12/2006 12:37:59 PM
dhawks
Status: offline
Tom,
Thanks for the info, that helps alot. BTW I was fortunate to get a close look at Bill Hempel's plane @ Tripple Tree during the Masters last week. It's a great looking design. I especially like the scale-like hinging. It sure looks like it flies nice too, but then again those guy's could fly the box it came in better than most of us could fly the plane.
Once again, really like what I've seen of your products,
Dennis
(in reply to rctom)
       Post #: 354
RE: Redesigned 28% Extra 300 Build / Que... - 10/14/2006 10:48:58 PM
Tricktrack
Status: offline
Has anyone had any problems with the gear being weak? On my second landing, albeit not perfect, but not terrible either, the gear on the left side twisted and bent backwards.
What are the options for replacement of this gear?
       Post #: 355
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 12:29:37 AM
bluehawkbm
Status: offline
I banged mine pretty good on one landing and the gear showed no signs of weakness, never even spread any.
(in reply to Tricktrack)
       Post #: 356
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 3:02:35 AM
cyoung450
Status: offline
I have the HD gear and it works very good.
CY
(in reply to bluehawkbm)
       Post #: 357
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 5:50:58 AM
WW2 Ace
Status: offline
quote:
ORIGINAL: cyoung450
CY
What is the "HD gear"?
"Learn from the mistakes of others, because you won't live long enough to make them all yourself"
WW2 Ace
       Post #: 358
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 6:41:51 AM
Tired Old Man
Status: offline
HD gear? Inquiring minds want to know...
Pat,
were you able to try any of those items we talked about?
(in reply to WW2 Ace)
       Post #: 359
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 1:49:58 PM
mrbigg
Status: offline
Anyone using just one battery for the reciever? I usually use two in case one fails, but I'm thinking of just using one Fromeco 4400 with the regulated reliaswitch that I can pull out of my Ultimate. That way I won't have to order new ones and get any heat from the wife when more packages show up.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
       Post #: 360
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 5:25:23 PM
rctom
Status: offline
I had some gears made from thicker material for the "landing challenged", they are noticeably heavier though.
I also have some composite gear that work very well, glass filled nylon. They are ugly as anything though.
TF
(in reply to mrbigg)
       Post #: 361
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 6:26:20 PM
Tired Old Man
Status: offline
Regarding batteries. I've run only a single 4,400 Lithion on all my stuff under 35% for years without an issue. I'm soon to be setting up my 35% Giles again and will only be using a single battery system this time. As in everything else secure your wiring to prevent stress at the connections and to prevent things from pulling apart.
If you want to save a lot of weight and can balance without issue consider using large 2s Lipolys and regulators for the electrical source. There are a few good sources of 4,000plus 7.4v lipolys now that weren't readily available a year ago. Not cheap, but they are light. Just follow the appropriate safety precautions when using them.
       Post #: 362
RE: Redesigned 28% Extra 300 Build / Que... - 10/15/2006 10:50:35 PM
mrbigg
Status: offline
you check the CG by measuring from the WINGTIPS right? If that's the way it is, at 3.5" it's still a little nose heavy. I set the rudder servo on the stab over the hole it will go in. Battery is as far back as possible without custom making a tray. I might put the ignition battery with it and run longer leads to the regulator which will still be up front. Think I'll get any glitches by doing this?
       Post #: 363
RE: Redesigned 28% Extra 300 Build / Que... - 10/16/2006 12:19:58 AM
WW2 Ace
Status: offline
quote:
ORIGINAL: Silversurfer
Pat,
Pat, unfortunately I have not been back out yet. I had the unfortunate landing the last time out and bent the gear pretty bad. Caught the tailwheel in the edge of some tall grass at the end of the runway and it basically yanked the plane out of the air and put a bad twist in the gear. I think it will require a replacement but I haven't decided if I will go with stock or something else. That was one reason I was inquiring about the !QUOT!HD Gear!QUOT!. I haven't herd back what that is or who sells it. I don't know if he was referring to Toms gear or something else.
Click to see fullsize image.
Click for fullsize
Click for fullsize
WW2 Ace
       Post #: 364
RE: Redesigned 28% Extra 300 Build / Que... - 10/16/2006 12:46:43 AM
Tired Old Man
Status: offline
I'd stay with the stock gear and just avoid the nasty area stuff. It would have prolly torn the leg off of carbon or glass gear.
For Mr. Bigg,
If you haven't flown the plane at 3-1/2" yet you should give it a try before you make any changes. If it does not then perform to your expectations then try moving the gear. As for glitches, that's something that depends very much on the equipment and the manner it's installed. As in every other installation a few range checks will tell all that's needed to know in that regard. Overall, it should work out fine.
       Post #: 365
