Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
OK, help me with some clarification on the receiver pack thing. If all the servos are are supplied power and driven via the reciever ports using a single battery system, where does the battery need to provide the additional power requirements through if a few servos are stalled or drawing high amp loads for one reason or another? Correct me if I'm wrong, but that power will be pulsed through the receiver via the receiver battery pack. Yes, no? Now if it just happens to be a redundant battery system and the receiver is supplied only by one battery, are all the servos supplied independantly via a separate battery pack? If so, does that mean some form of signal isolator or power expander needs to be used? Thanks for the help.
_____________________________
If you can''t fix it with a hammer, you have an electrical problem.
