rctom
TX, USA Status: offline
quote:
ORIGINAL: bluehawkbm Guys, I'd like to know what kind of batteries and regulator and switchs you all recommend. Do you think one 2400 Li Ion for the receiver and one for the ignition would be sufficient? Also I was looking at the MPI Miracle Switch. It has a regulator built in with a switch and charge port. Do any of you use these or should I go with the Formeco regulators. I am most likely going to run Hitech 645's for the elevator and ailerons and maybe a Hitech 5955 digital for the rudder. First, I recommend two batteries for the receiver. 2400 mah is probably enough capacity but does not give you any redundancy. Also LiIons are fairly limited in their current output ability, two of them would assure full power at all times. I have not tried the Miracle switch, but I plan to. TF
