Bobby Folsom
Joined: 3/11/2005 From: Vicksburg, MS, USA Status: offline
Silversurfer, yes that is also my exact setup, Cermark gold plated extensions and nothing else in the way of filters, chokes etc. A lot of what we have come to do as a matter of routing is a result of the early ignition-type engines like the old quadra weed eater engines that were converted to airplane use and had lots of fF interference. As a result of new technology in electronicsmand electronic ignitions we don't see as many of these kinds of problems as we use to. Now on to the fuel dot: I always put the fuel dot above the level of the tank top because when I remove my fuel probe from the fuel dot tubing I don't want fuel to syphon out onto the ground, plane or my foot!! Besides, it's that much less flying time if fuel syphons out! Simple fix if you've already installed you fuel dot is to glue a round piece of 1/32" light ply on the inside and cover over the hole on the outside with covering of the appropriate color. Then just cut a new hole at the "correct" poisiton and reinstall your fuel dot - VIOLA, your done. Bobby
