RE: Kingcat-Like Design and Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Kingcat-Like Design and Build
Page: <<   < prev  5 6 7 8 9 10 11 [12] 13 14   next >   >>
Login
RE: Kingcat-Like Design and Build - 4/18/2007 4:05:11 AM
RLPageMD
Status: offline
Mods, I watch for any new posts on this thread on a daily basis. Waiting in great anticipation for your release of this fabulous piece of artistry. I signed up for your pre-order list prior to your website creation. Should I sign up again there to keep my place or were you able to transfer that at the time of your website coming online? Thanks in advance, Rick
(in reply to rmenke)
       Post #: 276
RE: Kingcat-Like Design and Build - 4/18/2007 10:25:00 PM
Lomcevak Duck
Status: offline
I too requested to be on the list long before the website was up and I am hoping that I am still on it as I am guessing that the list is growing quite long by now.
_____________________________
When someone loses a plane in the pits, you do a lomcevak duck.
(in reply to RLPageMD)
       Post #: 277
RE: Kingcat-Like Design and Build - 4/19/2007 1:48:44 AM
Mods-R-Me
Status: offline
Thanks guys for checking in. Here is the Modkat pre-order list as of 18 April 07:
1. Rlpagemd
2. Jinzo
3. Timandchoc757
4. Sparhawk
5. Turbinecrazy
6. Arck
7. TBWood
8. Ayrtonsenna
9. Lomcevak Duck
10. Bob27
11. C. Mosa
12. J. Widner
13. macdonald77
If I missed anyone or if others would like to be added, please let me know.
Mods
Kelvin "Mods" Verrett
www.MRM-RCModels.com
(in reply to Lomcevak Duck)
       Post #: 278
RE: Kingcat-Like Design and Build - 4/19/2007 5:10:57 AM
Lomcevak Duck
Status: offline
Thanks Mods. Makes me feel better knowing that I'm still there. It says something for your design that so many people want to pre order a plane that has never been flown and still in the prototype phase. I imagine a lot more of us are going to want one when they see the finished product and get the first flight reports.
(in reply to Mods-R-Me)
       Post #: 279
RE: Kingcat-Like Design and Build - 4/19/2007 10:14:06 AM
Ayrtonsenna
Status: offline
I'm going to be very proud to represented MRM, possibly having the first Madcat in NEW ZEALAND!
Always watching kelvin......
Wishing you and your family all the best.
Ants
life.....you get one shot ...take it
       Post #: 280
RE: Kingcat-Like Design and Build - 4/21/2007 12:17:30 AM
Mods-R-Me
Status: offline
Fuse Plug #2-10
Got the bottom of the fairings done using the same technique as before (figures 1-6).
Figures 1 & 2
Figures 3 & 4
Figures 5 & 6
The constant sanding and shaping has made them very thin is some places. This is bad because the plug will require a little coaxing out of the mold. The thin portions would surely break off in the process. To prevent this, the fairing will be fiberglassed (this weekend) with heavy weight cloth on the top and bottom.
More to come,
Mods
< Message edited by Mods-R-Me -- 4/21/2007 12:19:42 AM >
(in reply to Ayrtonsenna)
       Post #: 281
RE: Kingcat-Like Design and Build - 4/21/2007 12:48:24 AM
arck
Status: offline
Hey Mod, your job is amazing but, I was wondering if that radio continuous working,,,he he,,,
Click to see fullsize image.
Click for fullsize
Dual Ace,Challenger II P,messerschmit .46,spitfire .25,sirius hot,upstar glid.,Fan Trainer,VDiamond P, blade cx2,Revo3.3 et
       Post #: 282
RE: Kingcat-Like Design and Build - 4/21/2007 1:09:41 AM
Mods-R-Me
Status: offline
quote:
ORIGINAL: arck
LOL! Yes, surprisingly enough with as much fiberglass and balsa dusts that has went into it .
(in reply to arck)
       Post #: 283
RE: Kingcat-Like Design and Build - 4/22/2007 11:21:39 PM
Mods-R-Me
Status: offline
Fuse Plug #2-11
Summary
Today, I glassed the fairings and applied the first coat of epoxy primer on the plug. Now, the fairings are very rigid. I can't bend or break them no matter how hard I try . Next, I have to wet sand the plug smooth, separate the hatch from the fuse, and one last coat of primer. Then, several coats of black enamel followed by MOLDS!!!!!!!!!!
Construction
First, the fairings area was outlined with painters tape (Figure 1). Then, I applied one layer of heavy weight fiberglass to the top and bottom of the wing saddle area (Figures 2 & 3). Followed by feathering the fiberglass to a fine edge (Figure 4). This was NOT fun. Even with 60 grit sandpaper it took 2 hours .
Figures 1 & 2
Figures 3 & 4
One last shape check with the grey Krylon primer (Figure 5). Here's the plug with a few thick coats of white epoxy primer (Figures 6-8).
Figures 5 & 6
Figures 7 & 8
More to come,
Mods
< Message edited by Mods-R-Me -- 4/22/2007 11:35:13 PM >
       Post #: 284
RE: Kingcat-Like Design and Build - 4/22/2007 11:32:47 PM
Lomcevak Duck
Status: offline
Beautiful work mods.
       Post #: 285
RE: Kingcat-Like Design and Build - 4/23/2007 1:20:05 AM
Sparhawk
Status: offline
Sweet Kelvin. I am half thinking of getting a Wren 44 to put on thtail of this little beasty!!
Spar
Oh great are the days my landings = my take-offs....!
Revver Bro #158
       Post #: 286
RE: Kingcat-Like Design and Build - 4/23/2007 1:50:10 AM
Mods-R-Me
Status: offline
quote:
ORIGINAL: Sparhawk
Spar
You read my mind! It would only take a few mods in the center section to make it happen. I would suggest placing an external fuel tank on the center station to make room for the additional equipment (FADEC, ECU, Pump, etc). After the maiden, I'm planning on offering an external payload pod for a camera or bomb drops.
Mods
(in reply to Sparhawk)
       Post #: 287
RE: Kingcat-Like Design and Build - 5/4/2007 1:16:45 PM
Mods-R-Me
Status: offline
Update: I found a new job in Yuma, Arizona so MRM-RCModels will be changing location AND setting up in a much bigger facility . Regretfully, there will be only a few Modkat updates for the next 3-4 weeks. Once the new shop is up, construction will resume.
Mods
       Post #: 288
RE: Kingcat-Like Design and Build - 5/4/2007 1:30:41 PM
bob27s
Status: offline
Congrats on the new job and good luck with the move !
(wish I had taken the Yuma job 12 years ago.... hindsight...)
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
