Mods-R-Me
CA, USA Status: offline
You know that feeling when your present project is 95% done and you see the most attractive aircraft that you just have to build. Right then you have to make a decision, finish the one you're on or follow your hearts desire and start the new one. I choose the latter. This is my new project.... This pic is of a Kingcat, but the problems are: 1. It's an ARF (don't do ARFs) 2. It's a turbine (would like to do it, but way too much $$$$) 3. BVM does not produce it in kit form This (coupled with my insatiable need to build) inspired me to design my own and like my handle implies heavily modify it. First and foremost I plan to turn it into a 0.90 size cowled pusher prop. If all goes well I will kit the plane and make it available to the public. To keep everything fair and honest I called BVM to ask if I could design and sell a similar design to the Kingcat. Their only requirement is that I do not use "cat" in the name. Awesome guys . Here are the design specs so far: 1. Power Plant: BSE Jett 90L Rear Exhaust (muffler routed through the fuse) 2. Weight: 8-9lbs 3. Wingspan: 50", fuse length: 60" 4. Spring Air 100 Retracts 5. 6 channels (standard four, retracts, and flaps) 6. Airfoil: NACA 0010 root to tip with 1 degree of washout 7. Balsa build-up wings with fiberglass fuse and twin booms 8. The engine will have a custom molded fiberglass cowl 9. The fuel cells will be mounted in the wings
< Message edited by Mods-R-Me -- 9/1/2006 7:16:54 PM >
_____________________________
Kelvin "Mods" Verrett www.MRM-RCModels.com
