RE: Nitro models pusher Bobcat?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
Page: <<   < prev  145 146 [147] 148 149 150 151 152 153 154   next >   >>
Login
RE: Nitro models pusher Bobcat? - 2/24/2009 10:48 PM
HeliTB
Score: 100
Last Login: 2/8/2013
Status: offline
SinCityJets...I posted your link for the Bobcat/Falcon .25 turbine video in the other RC ???? website where we actually discuss the Bobcat .25 electric/nitro, well mostly electric. I thought the guys would like to see what Kolibiri is up to.
Are you offering any discount or financing options? :-) LOL
_____________________________
Raptor v2 OS 37/Bobcat Jet OS .55 AX
Extra 330L 25% SV26cc/SIG Kougar OS .46 AX
Hide Signatures
(in reply to cyborg1)
       Post #: 3651
RE: Nitro models pusher Bobcat? - 3/2/2009 4:49 PM
airborne14830
Score: 100
Last Login: 4/1/2013
Status: offline
What is the right way to install the pusher prop on the engine? I have an APC 11x7 I want to install. Do the numbering 11x7 face the the nose of the plane or does the numbering face the rear?
airborne crazy
Hide Signatures
(in reply to HeliTB)
       Post #: 3652
RE: Nitro models pusher Bobcat? - 3/2/2009 7:00 PM
HeliTB
Score: 100
Status: offline
If it is a pusher prop 11x7p the writing should be toward the motor, meaning toward the front of the airplane.
Hide Signatures
(in reply to airborne14830)
       Post #: 3653
RE: Nitro models pusher Bobcat? - 3/2/2009 7:13 PM
Crazy4Flight
Score: 110
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: airborne14830
to the rear.....for APC
CAUTION: it depends on the brand of prop you use !!!
on wood props from topflite the writing faces forward.
on APC props the cast in numbers face to the rear ( it mounts just like an APC tractor prop on regular airplane)
bob
Hide Signatures
       Post #: 3654
RE: Nitro models pusher Bobcat? - 3/3/2009 12:14 AM
airborne14830
Score: 100
Status: offline
The prop is an APC 11x7p with cast in numbering so which way is the numbering facing ( towards the front facing the engine or nose, or is the numbering facing away from the engine and twowards the elevator)? just looking for clarification
Also, does it mater that i balance the plane inverted?
thanks
airborne crazy
Hide Signatures
(in reply to Crazy4Flight)
       Post #: 3655
RE: Nitro models pusher Bobcat? - 3/3/2009 12:42 AM
Crazy4Flight
Score: 110
Status: offline
the numbers would be facing the eleevator,.
APC pusher props mount tho your motor in the same way a tractor prop
Hide Signatures
       Post #: 3656
RE: Nitro models pusher Bobcat? - 3/3/2009 12:47 AM
HeliTB
Score: 100
Status: offline
I have an OS AX .55 with 11x7p and the writing is toward the nose and the engine. It's an APC. I've flown my Bobcat twice.
Hide Signatures
       Post #: 3657
RE: Nitro models pusher Bobcat? - 3/3/2009 1:03 AM
Crazy4Flight
Score: 110
Status: offline
it is on backwards! it will make thrust but not as much as it should.
in this case you have enough power to make the plane fly.
look at the hub of the prop lettering like C-2 should be towards the prop nut - elevator
look at the hub of the prop lettering like 11x7P should be towards the prop nut - elevator
you will be astounded by the proformance gain.
I once had one on bassackwards and it was lathargic.
Hide Signatures
       Post #: 3658
RE: Nitro models pusher Bobcat? - 3/3/2009 1:10 AM
airborne14830
Score: 100
Status: offline
Thanks for the feedback, I will make that happen. Also how about balancing the plane, I did mine inverted any issues with that?
airborne crazy
Hide Signatures
       Post #: 3659
RE: Nitro models pusher Bobcat? - 3/3/2009 1:15 AM
Crazy4Flight
Score: 110
Status: offline
no just makes the task of balance easyer nose or tail will drop but not as fast.
Hide Signatures
       Post #: 3660
RE: Nitro models pusher Bobcat? - 3/3/2009 9:35 PM
HeliTB
Score: 100
Status: offline
Crazy4Flight...I will take your word that you are correct and change the direction of my prop. It will be scary to see any performance gain as with the prop backwards I believe my Bobcat was pushing 100+ mph.
Hide Signatures
       Post #: 3661
RE: Nitro models pusher Bobcat? - 3/4/2009 3:44 PM
HeliTB
Score: 100
Status: offline
Crazy4Flight...I checked my prop direction last night. If I face the 11x7p towards the prop nut it will be spinning backwards. The trailing edge of the prop would cutting into the wind if I put 11x7p towards the nut.
Again my prop is an APC pusher prop. I'm going to leave my prop the way it is with the 11x7p facing towards the plane/engine, because the leading edge of the prop is cutting the wind.
Hide Signatures
       Post #: 3662
RE: Nitro models pusher Bobcat? - 3/4/2009 7:56 PM
BillS
Score: 100
Last Login: 5/25/2013
Status: offline
I have six different APC pusher props. Most have the size towards the nut but the 11 x 7p has the size towards the engine.
Bill
Hide Signatures
       Post #: 3663
RE: Nitro models pusher Bobcat? - 3/5/2009 1:30 AM
SU-31 flyer
Score: 100
Last Login: 5/22/2013
Status: offline
I just got two new APC 11X7P for mine and the lettering will be toward the elevator. Just thought I would chime in here.
Hide Signatures
(in reply to BillS)
       Post #: 3664
RE: Nitro models pusher Bobcat? - 3/5/2009 2:11 AM
Crazy4Flight
Score: 110
Status: offline
well looks like APC goes both ways, depends on the prop.
user must take care to install...watch the curve and camber of the prop...
A pusher prop wil makeabout 60% the thrust if installed bassackwards.
been there done that, and the bobcat flew just barely!
ok here are my props that were in the hangar. APC 10x6p 10x7p 10x8p
first pic F these are facing towards the nose
2nd pic R these are facing towards the tail.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Crazy4Flight -- 3/5/2009 2:47 AM >
Hide Signatures
(in reply to SU-31 flyer)
       Post #: 3665
RE: Nitro models pusher Bobcat? - 3/5/2009 5:30 AM
HeliTB
Score: 100
Status: offline
Crazy4Flight...Please accept my apology. I have a 10x7p on my Bobcat with the C-2 towards the elevator and the writing 10x7p towards the motor. My 11x7p props will be as you stated C-2 and writing 11x7p towards elevator.
To all, Crazy4Flight was correct. My bad.
Hide Signatures
       Post #: 3666
RE: Nitro models pusher Bobcat? - 3/8/2009 7:22 AM
BillS
Score: 100
Status: offline
For what it is worth the Tower .75 just purchased turns a 11 x 7p APC prop at 14,700 rpm. The engine probably needs more prop. Also the low speed seemed unusually fat after working with it until time ran out. Will work more with the low speed tomorrow.
Bill
Hide Signatures
       Post #: 3667
RE: Nitro models pusher Bobcat? - 3/11/2009 12:57 AM
AGR413
Score: 100
Last Login: 1/25/2013
Status: offline
I another thread in extreme speed prop planes essentially the same question was asked about the prop for the TH .75. As I posted there the best performance I have had was with the 12x6 zinger. But they break easy. I have put in an email request to APC to please make some 12x6 and 13x6 pusher props for these types of applications maybe if others joined in they would. Another suggestion was the graupner 11x8 which I may give a shot.
Here is what I sent APC:
quote:
Hi,
Please consider making some 12x6 and 13x6 pusher props for engines such as the Tower Hobbies .75. The only option I have found in this category is the zinger 12x6 pusher which gives great results but is too fragile. There are many pusher models that are popular these days and many modelers are using Tower and Os .75 engines. The prop of choice has been the APC 11x7 because of availability but it does not load the engine enough.
PS
This thread: http://www.rcuniverse.com/forum/m_4588799/anchors_4588799/mpage_1/key_/anchor/tm.htm#4588799
Applies to one of the planes I referred to and is a huge thread with a great deal of interest (147 pages long).
If you are flying, life is good.
Hide Signatures
(in reply to BillS)
       Post #: 3668
RE: Nitro models pusher Bobcat? - 3/11/2009 7:33 PM
BillS
Score: 100
Status: offline
quote:
TH .75. As I posted there the best performance I have had was with the 12x6 zinger. But they break easy. … Another suggestion was the graupner 11x8 which I may give a shot.
I ordered a 11 x 8 Graupner pusher and should know how it loads the engine when it arrives.
Bill
Hide Signatures
(in reply to AGR413)
       Post #: 3669
RE: Nitro models pusher Bobcat? - 3/12/2009 6:27 AM
cyborg1
Score: 100
Last Login: 9/24/2012
Status: offline
I believe that Opjose is getting very good results with the Graupner 11x8p. I've ordered them already, but haven't had time to test them with my OS 75ax yet. The APC 11x7 screams with the OS 75. I believe that you should be able to get about 13k with this combination.
Hide Signatures
(in reply to BillS)
       Post #: 3670
RE: Nitro models pusher Bobcat? - 3/12/2009 7:21 AM
SinCityJets
Score: 115
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: HeliTB
HTB,
I apologize for not responding sooner. I don't usually track this thread and didn't see your post.
Unfortunately, there isn't much mark up in these turbines. As you probably already know, they are pretty difficult to come by, and a second-hand market doesn't exist (at this time). These turbines seem to be like fine watches. once you have one, you just keep flying it. I have never been as impressed with a mechanical object as I have with these turbines.
What I can offer is outstanding support and quick delivery!!
Chad
Hide Signatures
       Post #: 3671
RE: Nitro models pusher Bobcat? - 3/16/2009 6:54 PM
BillS
Score: 100
Status: offline
Wonder if there will be any more Bob Cat’s produced this year? If not I am looking for a yellow fuselage as a spare.
Bill
Hide Signatures
(in reply to SinCityJets)
       Post #: 3672
RE: Nitro models pusher Bobcat? - 3/17/2009 4:29 AM
N1EDM
Score: 125
Status: offline
Hello Chad,
I'm just catching up on this thread... just found it. Could you point me to the post about the Turbines, or a link to where I could check them out on the web? Are you talking about the full-sized Bobcat or the smaller Falcon/Bobcat 25?
Thanks.
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
       Post #: 3673
RE: Nitro models pusher Bobcat? - 3/17/2009 4:56 AM
XJet
Score: 100
Last Login: 3/24/2009
Status: offline
Is the factory that makes the bobcats even still in business?
Since I started making pulsejets for these ARFs (and the Long-EZ), all supply of them seems to have dried up so now I'm looking for new airframes.
I'm wondering if they might have been the product of one of the growing number of Chinese ARF-makers that have ceased trading in recent months.
Hide Signatures
(in reply to N1EDM)
       Post #: 3674
RE: Nitro models pusher Bobcat? - 3/17/2009 5:52 AM
HeliTB
Score: 100
Status: offline
Go to RCG and type Falcon .25 turbine select forum and then go to last page
Hide Signatures
(in reply to XJet)
       Post #: 3675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.017RCU1
