RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  119 120 [121] 122 123 124 125 126 127 128   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 3/5/2008 6:23:51 AM
    mattosan1
    Status: offline
    Tumbler, Wow your Falcon25 looks very fast and I must say good pilot work!!!
    I am sure the setup for my Bobcat will fly great (9lbs thrust vs 8lbs 2oz RTF) but this motor is 610kv @ 6s will only yield 13,500 rpm max so it may not be as fast as you seem like you want to go... If you want huge speed you may have to go EDF setup (high amperage = high cost = high speed). Matto...
    (in reply to TUMBLER)
           Post #: 3001
    RE: Nitro models pusher Bobcat? - 3/5/2008 1:20:19 PM
    reb92
    Status: offline
    quote:
    ORIGINAL: Stick Jammer
    quote:
    ORIGINAL: reb92
    I have alread installed the gas tank on my bobcat 50 facing the rear - It is going to be a pita to get it out - What potential problems am I facing with this set up - I now relize that I cannot let it get to low on fuel before landing...Any other major concerns? TIA
    BTW - Engine OS 55AX 11x7 APC Pusher
    Well, it will be more of a PITA to gather all the pieces and throw them in a trash bag cause it's gonna flame out for sure. It will not work with the clunk forward in the tank. The second you go vertical the clunk is high and dry. Even level flight won't take long for it to suck air. Are your wings glued on? If not, it isn't that big of a deal. If they are glued, the anti-rotation rod is probably in the way to remove the tank. I would do whatever it takes to turn that tank around.
    Unfortunatly the wings are glued - I also put velcro on the bottom of the tank to hold in place a little better...bad Idea - This is not going to be easy. Thanks for the replies.
    (in reply to Stick Jammer)
           Post #: 3002
    RE: Nitro models pusher Bobcat? - 3/5/2008 5:34:00 PM
    opjose
    Status: online
    You can cut the wood off the former at the front of the fuel tank w/o problems.
    Cut it on either side of the tank so that you can later replace it with wood stock accross the cut area, which you can in turn screw in place.
    I did this to make my tank easier to replace and remove, since I typically pull each plane's tank once each season to check everything.
    This will permit you to push the tank "up" then forward and out with enough clearance.
    _____________________________
    Build em'', fly em'', crash em'' and build more.
    (in reply to reb92)
           Post #: 3003
    RE: Nitro models pusher Bobcat? - 3/5/2008 6:44:37 PM
    amcleod
    Status: offline
    I've got a GMS .25 engine here, looking for an airframe. Would one of the BobCat 25s fly OK with that engine? All the BobCat 25s I've read about in here seem to be electric powered or have .32s in them.
    I don't require the model to be a brain-blistering speed-daemon, but I don't want it to be a complete, unflyable slug, either.
    Angus
    (in reply to opjose)
           Post #: 3004
    RE: Nitro models pusher Bobcat? - 3/5/2008 9:24:33 PM
    Stick Jammer
    Status: offline
    Original: reb92
    If your wings are glued securely, you should be able to cut the anti-rotation rod with a hacksaw blade. This will take a little effort but at least you can get the tank out. I'm sure you gained a valuable lesson and it probably goes without saying, but never install a fuel tank that can't be removed. Good luck on the surgery.
    The more you fly, the more you buy.
    (in reply to reb92)
           Post #: 3005
    RE: Nitro models pusher Bobcat? - 3/5/2008 10:41:51 PM
    Meekskin
    Status: offline
    amcleod,,,,use the os 32 and you will be very happy. Use the os 25 and it barely flies. The 25 is not close to being enough engine.
           Post #: 3006
    RE: Nitro models pusher Bobcat? - 3/6/2008 2:08:30 AM
    amcleod
    Status: offline
    quote:
    ORIGINAL: Meekskin
    I don't have a 32. I'm looking for an aeroplane that I can use my existing 25 on. If the BobCat 25 won't work, then too bad! I will have to find something else for that engine. Still planning to buy one of the bigger BobCats, and equip it with retracts and a 75, but I'm not going out and buy a 25-sized BobCat and 32 motor as well.
    I was just hoping the 25 would fly the, uh 25-sized BobCat.
    Angus
    (in reply to Meekskin)
           Post #: 3007
    RE: Nitro models pusher Bobcat? - 3/6/2008 2:51:00 PM
    reb92
    Status: offline
    quote:
    quote:
    ORIGINAL: Meekskin
    Great Planes has a spitfire .25 size that is real fun to fly - You might want to try one of those.
    (in reply to amcleod)
           Post #: 3008
    RE: Nitro models pusher Bobcat? - 3/7/2008 2:33:09 PM
    airborne14830
    Status: offline
    Do you have to do anything special with your engine to turn a pusher prop in the right direction? I have a evolution .61 that I would like to install in my Nitro Bobcat 50. Also, will the motor mounts be strong enough for this type of engine as well?
    Also, can anyone point to the right thread that outlines how to mount your wings using bolt versus gluing? I am just trying to figure out which method is better.
    airborne crazy
    (in reply to reb92)
           Post #: 3009
    RE: Nitro models pusher Bobcat? - 3/7/2008 4:52:11 PM
    opjose
    Status: online
    quote:
    ORIGINAL: amcleod
    Heh...
    I am awaiting a GMS .32 to put in my Bobcat 25, which is currently electrically powered.
    I finally got the speed I wanted out of it by putting in TWO 4800mAh 11V packs in a 6S1P configuration to produce 22v @ 600 watts or so.
    I realized that this was about the equivalent of a .25 engine, and that the .25 engine with 4oz of fuel would weight a heck of a lot less than my two big packs, so I decided to convert it back to glow.
    The .25 should do fine with the right prop. I want to push it as fast as possible to I'm going with the .32.
           Post #: 3010
    RE: Nitro models pusher Bobcat? - 3/7/2008 4:54:01 PM
    opjose
    Status: online
    quote:
    ORIGINAL: airborne14830
    Except for a very few engines, most glow engines cannot have their rotation directions reversed.
    That means that you MUST use a pusher prop.
    (in reply to airborne14830)
           Post #: 3011
    RE: Nitro models pusher Bobcat? - 3/8/2008 1:48:48 AM
    Stick Jammer
    Status: offline
    When using a pusher prop, the engine turns in the same direction as it would with a standard prop. This would be counter-clockwise when looking at the front of the engine. Just make sure you have the pusher prop orientation correct, the trailing edge is much thinner than the leading edge. The engine blocks that come with the plane are usable but fairly soft, I chose to make new ones from hardwood. I'm not a fan of gluing the wings on for the simple reason of maintenance and/or repairs. You're in the right thread, you just need to go back and do some reading. Trust me, its well worth your time.
           Post #: 3012
    RE: Nitro models pusher Bobcat? - 3/9/2008 5:52:33 AM
