RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  123 124 [125] 126 127 128 129 130 131 132   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 4/7/2008 12:19:14 PM
    Boomerang1
    Status: offline
    Here's how the previous owner set up the nosewheel steering on mine. Just epoxied a ply plate to the side of the retract & epoxied the servo to that.
    A bit rough for my liking but it's all glued with Hysol so I'd probably destroy everything if I tried to pull it apart & re do everything. - John.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by Boomerang1 -- 4/7/2008 12:26:31 PM >
    _____________________________
    Distributor for: Nothing! So my posts can be unbiased.
    (in reply to Pit-Viper 1)
           Post #: 3101
    RE: Nitro models pusher Bobcat? - 4/7/2008 11:07:52 PM
    amcleod
    Status: offline
    quote:
    ORIGINAL: littlepiston
    why dont you get springair retracts at retracts.com they are whay better imo about 150 for the set with air suport complete. if your going to use wire landing gear the 101hd's are the ones you need.If using eleos the 701's .these include firwall mount nose retract
    I'd be OK with trying Spring Air retracts, but how well does the firewall-mounted nose unit fit in the retract-ready Bobcat that is apparently designed for a rail-mounted unit? I've never used pneumatic retracts before so I'm a little afraid of buying totally the wrong bits. The retracts.com website is a little short in info for first-timers like myself. There aren't too many people around here that will pay to take my mistakes off my hands!
    As I understand it, you can't install wire struts now and retro-fit oleos later, and I simply can't afford to pay for the 701s and a set of struts right now, so I'll probably go for the 101s instead.
    Angus
    (in reply to littlepiston)
           Post #: 3102
    RE: Nitro models pusher Bobcat? - 4/8/2008 2:59:20 AM
    littlepiston
    Status: offline
    every retract requires some modification to fit period the 701s and the robarts 520s are the same mounting size. with the exception of the nose retract on either
    (in reply to amcleod)
           Post #: 3103
    RE: Nitro models pusher Bobcat? - 4/8/2008 3:53:14 AM
    thebluemax
    Status: offline
    quote:
    ORIGINAL: amcleod
    Angus,
    I originally purchased the Spring-Air 305's for mine, which is the rail mounted nose gear. I put Robart 3/8th inch struts on mine although if you are strapped for cash the 305's should be just fine without them.
    My Bobcat as not the retract ready version so I had a lot of work to do to mount them. I tried to mount my nose gear on a motor mount and then mount it to the bulkhead. But when I went to mount the nose gear the bulkhead was not square. So I ended up getting the 305 nose gear which is the bulkhead mount and used a wedge plate to adjust the angle so it was all square. With the wedge plate in there was not enough space for my motor mount idea so I needed he bulkhead one .
    If you get the 305's you should not have any real problems. The Spring-airs install fairly easily and this was the first set of retracts I ever did. If I had the retract ready version the job would have been even easier.
    Living the dream....
           Post #: 3104
    RE: Nitro models pusher Bobcat? - 4/8/2008 3:57:00 AM
    dc10capt
    Status: offline
    Installed a Jett 90lx on my Bobcat 52 with an APC 11x7 pusher......man this thing moves!.....115 mph on the radar. i'm going to build a new one with retracts....heavy duty retracts. i'm hoping for 125mph.
           Post #: 3105
    RE: Nitro models pusher Bobcat? - 4/8/2008 5:48:54 AM
    amcleod
    Status: offline
    quote:
    ORIGINAL: thebluemax
    Ok, now I'm confused. If I buy a set of retract units that come with wire legs (like the 305s, 101s or Robart 520W1s) can I later replace the wire legs with oleo struts? I thought that if a set or retracts was built for wire it could not accommodate oleos and if it was built for oleos it could not accommodate wire legs. I've never seen a set of pneumatic retracts. There is nobody around here who has a set I can go and look at.
    Angus
    (in reply to thebluemax)
           Post #: 3106
    RE: Nitro models pusher Bobcat? - 4/8/2008 6:09:37 AM
    thebluemax
    Status: offline
    quote:
    ORIGINAL: amcleod
    Angus,
    My intention was not to confuse you . Take a look at this thread. click here for the thread
    Look at posts 3 to 14 and you will see what this person did. He did not use Spring-airs but the process is the same. This is what I used as a guide when I did mine.
           Post #: 3107
    RE: Nitro models pusher Bobcat? - 4/8/2008 10:18:44 AM
    Boomerang1
    Status: offline
    No idea. The Bobcat I have was the fixed gear version & converted by the previous owner. - John.
           Post #: 3108
    RE: Nitro models pusher Bobcat? - 4/8/2008 10:48:48 PM
    Stick Jammer
    Status: offline
    Original: amcleod
    I can't speak for the Spring Airs but the Robarts can be converted to Robo Struts anytime you wish. You simply cut the wire to the correct length and secure the struts to the wire stubs. I would imagine the same is true for any wire retract.
    The more you fly, the more you buy.
           Post #: 3109
    RE: Nitro models pusher Bobcat? - 4/9/2008 3:08:58 AM
    amcleod
    Status: offline
    Ok, other than $40 in price, can anyone tell me what the difference is between the 101s and the 301s? The product photos at retracts.com for these two items are exactly the same.
    Angus
    (in reply to Stick Jammer)
           Post #: 3110
    RE: Nitro models pusher Bobcat? - 4/9/2008 3:16:23 AM
    hapyjac2
    Status: offline
    Angus,
    The 300's have a lower profile, I have used the 100 series on my Bobcat and powered it with a small turbine, with very good success. I did have the early model that was not retract ready but they worked fine.
    "I never crash, just an occassional mid-air with the Earth"
           Post #: 3111
    RE: Nitro models pusher Bobcat? - 4/11/2008 11:37:28 PM
    Heli-NuBee
    Status: offline
    Completed my Yellow Bobcat 50 today. Yellow Bobcat 50, Tower 75 engine, Zinger 12x6P prop, Robart W1 retracts and Spektrun DX7 radio. This is my second attempt at this aircraft. The first one I had was distroyed on the maiden takeoff due to engine flame out. The engine flamed out on takeoff at approx. 10 to 15 feet above ground and the plane just rolled off to the right side and went in on the nose making mince meat of the fuselage. The first one I had was a fixed gear version and I was just going to purchase a new fuselage and canopy but the new retract version went on sale at almost the same price as the repair parts. I took everything out of the old plane and gave it to someone at our flying field that thinks he can somehow repair it. I hope I have a bit more luck with this one and should be doing the maiden within the next couple of weeks.
    Best wishes and good safe flying.
    Heli-NuBee (Roger)
    (in reply to hapyjac2)
