thebluemax
NJ, USA Status: offline
quote:
ORIGINAL: amcleod quote:
ORIGINAL: littlepiston why dont you get springair retracts at retracts.com they are whay better imo about 150 for the set with air suport complete. if your going to use wire landing gear the 101hd's are the ones you need.If using eleos the 701's .these include firwall mount nose retract I'd be OK with trying Spring Air retracts, but how well does the firewall-mounted nose unit fit in the retract-ready Bobcat that is apparently designed for a rail-mounted unit? I've never used pneumatic retracts before so I'm a little afraid of buying totally the wrong bits. The retracts.com website is a little short in info for first-timers like myself. There aren't too many people around here that will pay to take my mistakes off my hands! As I understand it, you can't install wire struts now and retro-fit oleos later, and I simply can't afford to pay for the 701s and a set of struts right now, so I'll probably go for the 101s instead. Angus, I originally purchased the Spring-Air 305's for mine, which is the rail mounted nose gear. I put Robart 3/8th inch struts on mine although if you are strapped for cash the 305's should be just fine without them. My Bobcat as not the retract ready version so I had a lot of work to do to mount them. I tried to mount my nose gear on a motor mount and then mount it to the bulkhead. But when I went to mount the nose gear the bulkhead was not square. So I ended up getting the 305 nose gear which is the bulkhead mount and used a wedge plate to adjust the angle so it was all square. With the wedge plate in there was not enough space for my motor mount idea so I needed he bulkhead one . If you get the 305's you should not have any real problems. The Spring-airs install fairly easily and this was the first set of retracts I ever did. If I had the retract ready version the job would have been even easier.
_____________________________
Living the dream....
