RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
Users viewing this topic: schock, mardio
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  124 125 [126] 127 128 129 130 131 132 133   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 4/20/2008 12:16:25 PM
    tizer33
    Status: offline
    Hi i had kinda made my mind up to get a OS 55ax or should i get the OS 75ax? I just dont know i wanted to keep it as light as possible- But also as fast as poss!
    Regards
    Tim
    (in reply to opjose)
           Post #: 3126
    RE: Nitro models pusher Bobcat? - 4/20/2008 5:09:47 PM
    Meekskin
    Status: offline
    Go with a Magnum 52,,,,faster than both those you listed. Mine flies 121 mph.
    (in reply to tizer33)
           Post #: 3127
    RE: Nitro models pusher Bobcat? - 4/24/2008 2:23:17 AM
    Stick Jammer
    Status: offline
    quote:
    ORIGINAL: tizer33
    Regards
    Tim
    I don't think the OS .75AX would be a good choice due to the extra weight and the fact that you probably wouldn't be able to prop it correctly on this plane. Can't go wrong with the .55AX, APC 11x7p, and 15% nitro. A lot of guys have high expectations for record breaking speed from this plane but the fact is this airframe is not really built for speed. It will scoot along rather well with the right setup but at the end of the day it's a glow powered sport jet. [)]
    _____________________________
    The more you fly, the more you buy.
           Post #: 3128
    RE: Nitro models pusher Bobcat? - 4/24/2008 2:46:48 AM
    Meekskin
    Status: offline
    nicely stated stick jammer
    (in reply to Stick Jammer)
           Post #: 3129
    RE: Nitro models pusher Bobcat? - 4/25/2008 4:03:20 PM
    patzane
    Status: offline
    My first one had a TH 75 and push this bobcat around well. I now have the retract ver with an OS 55. The 55 push it well, but I the the speed with the 75 little better. I will stick with the 55 as the engine is new so it still be broken in
    Don't go where the path leads
    But go where there is no path
    (in reply to Meekskin)
           Post #: 3130
    RE: Nitro models pusher Bobcat? - 4/25/2008 5:20:14 PM
    opjose
    Status: offline
    quote:
    ORIGINAL: Stick Jammer
    I disagree.
    I'm flying the GMS .76 which has a slightly higher bHP rating ( if you believe the manufacturer ) with the Graupner 11x8P prop, which is a perfect combo.
    This is in the same power and weight range as the OS .75AX.
    I'd stack either engine in this configuration against the .55AX this way.
    Build em'', fly em'', crash em'' and build more.
           Post #: 3131
    RE: Nitro models pusher Bobcat? - 4/25/2008 5:24:33 PM
    Meekskin
    Status: offline
    I'll put my bobcat with the Magnum 52 against any 75 motor and I think I will win.
           Post #: 3132
    RE: Nitro models pusher Bobcat? - 4/25/2008 5:31:36 PM
    opjose
    Status: offline
    quote:
    ORIGINAL: Meekskin
    You're on!
    With the Graupner 11x8P you'll eat my wake!
           Post #: 3133
    RE: Nitro models pusher Bobcat? - 4/25/2008 6:05:13 PM
    Meekskin
    Status: offline
    Opjose,,,I don't thinks so...all you will see is the prop on my bobcat and when we land, you will need 2 rolls of towels to clean the fuel resudue from your plane. LOL.....Our club would love for you to bring your bobcat to our site and fly against the other bobcat s the members have. Actually, you would need to work you way up the chain to get to me.)
           Post #: 3134
    RE: Nitro models pusher Bobcat? - 4/25/2008 10:52:42 PM
    tizer33
    Status: offline
    Thanks for the info , think im gonna go os55 because if i get a 75 then i should of got a 90 you see.
    What do you mean difficult to prop? because the best size inst available or ground clearence?
    Tim.
           Post #: 3135
    RE: Nitro models pusher Bobcat? - 4/25/2008 10:55:59 PM
    tizer33
    Status: offline
    Meekskin what prop you got on the magnum 52, i had a look for it in the uk but couldnt find it
           Post #: 3136
    RE: Nitro models pusher Bobcat? - 4/25/2008 10:56:26 PM
    opjose
    Status: offline
    He believes that it is difficult to get the correct prop for the .75AX in a pusher configuration.
    However the Graupner 11x8P is perfect for a .75 engine.
    It will produce higher airspeed than the 11x7P used on the .55AX.
    Which is why mine will leave his in it's wake.
           Post #: 3137
    RE: Nitro models pusher Bobcat? - 4/25/2008 11:12:59 PM
    tizer33
    Status: offline
    The old irvine 40 i got turns a 11*6 shows its still a good un
    Make sure you video the race
           Post #: 3138
