RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  125 126 [127] 128 129 130 131 132 133 134   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 4/27/2008 5:28:13 AM
    Meekskin
    Status: offline
    caiman, the answers to your question...NO and YES.....AND on the canopy, you really need to use screws because you will need to remove it for maintance.
    (in reply to caiman)
           Post #: 3151
    RE: Nitro models pusher Bobcat? - 4/27/2008 5:32:37 AM
    caiman
    Status: offline
    Do you mean it can't be flown with the 46FX, or just that it's not the best choice?
    (in reply to Meekskin)
           Post #: 3152
    RE: Nitro models pusher Bobcat? - 4/27/2008 5:39:41 AM
    Meekskin
    Status: offline
    I guess you can use a 46, but you won't like the perfromance. really not enough motor for the Bobcat,,,,IMHA.....
           Post #: 3153
    RE: Nitro models pusher Bobcat? - 4/27/2008 6:25:04 AM
    rifraff
    Status: offline
    thanks for the reply Stick Jammer, i found the corect CG by reading most of the forums here.
    he needs to know the wings get glue on correct?, also the servo mounting ect, still it would be nice to have the manual just so he can have an idea of where things are to be installed.....
    (in reply to Stick Jammer)
           Post #: 3154
    RE: Nitro models pusher Bobcat? - 4/27/2008 7:21:10 AM
    AGR413
    Status: offline
    I think you guys need to relax about the engine choice/speed deal. I used a doppler program on my original bobcat video and found the top speed to be 108 with a still breaking in engine set very rich on a 12x6 zinger. I have since put on a pitts muffler and switched to an 11x7 APC and it is much faster now. BTW my bobcat is without retracts. Others have mentioned the limitation for speed on this airframe has more to do with the airframe not the engine.
    This is by the way a tower .75. I have done the math earlier in this thread look for yourself.
    _____________________________
    If you are flying, life is good.
    (in reply to rifraff)
           Post #: 3155
    RE: Nitro models pusher Bobcat? - 4/27/2008 12:21:52 PM
    Stick Jammer
    Status: offline
    quote:
    ORIGINAL: caiman
    There have been a few reports of the Bobcat 50 being flown with a .46FX but I have to agree with Meekskin, you will likely be disappointed with the performance. On the wing attachment question, I used two 6-32 screws and blind nuts per wing but I did away with the anti-rotation rod. I also added a landing gear strap close to the trailing edge on the bottom of each wing.
    The more you fly, the more you buy.
           Post #: 3156
    RE: Nitro models pusher Bobcat? - 4/27/2008 12:30:11 PM
    Stick Jammer
    Status: offline
    quote:
    ORIGINAL: rifraff
    I'm not a fan of gluing the wings on this plane for the simple reason of maintenance and/or repairs. Servo mounting is pretty straight forward and to be honest the manual isn't really a lot of help if you don't have some experience. I suppose you could probably contact Nitroplanes to see if they could send you a manual.
           Post #: 3157
    RE: Nitro models pusher Bobcat? - 4/27/2008 6:25:30 PM
    caiman
    Status: offline
    I installed just one screw and blind nut on each wing, between the antirotation rod and the big tube used to attached the wings to the fuselaje. The problem is that I had to enlarge the antirotation rod holes on the wings a little bit since otherwise the wings were not parallel to each other and the airplane would bank as if you were applying ailerons.
    My concern is if one (well tighted) screw would be enough to prevent the wings from rotating (due to the enlarged antirotation rod hole).
    About the 46FX engine, do you think I would risk stalling the airplane with that engine, or the lack of performance you talk about is more like for very fast flying?
    I hope my explanation was clear enough.
    Thanks.
           Post #: 3158
    RE: Nitro models pusher Bobcat? - 4/27/2008 6:45:51 PM
    Meekskin
    Status: offline
    In my opinion the 46 doesn't have the necessary power to fly a plane of this size. Even without retracts, the bobcat is designed to fly on the fast side. Try to get at least a 52 or 61 size engine and you will like the flying.
           Post #: 3159
    RE: Nitro models pusher Bobcat? - 4/28/2008 12:41:44 AM
    caiman
    Status: offline
    Will it fly well with an OS 55AX?
    Which prop would you recomend for the 55AX?
           Post #: 3160
    RE: Nitro models pusher Bobcat? - 4/28/2008 12:49:43 AM
    Meekskin
    Status: offline
    Yes, I think that would be a good engine, however, for a lot less money, you can get a Magnum 52 which I think moves the bobcat with very good speed. Use a 11X7 pusher prop on both engines and you will be a happy flyer.
           Post #: 3161
    RE: Nitro models pusher Bobcat? - 4/28/2008 2:08:36 AM
    Wingspam
    Status: offline
    I have an Os 46 with an 11x6 p and it fly's at a very average speed of 54 mph. I now have a 55 ax on it and waiting for my thrust muffler to come in. I am hoping this will get me around 100 mph...
    Wingspam
           Post #: 3162
    RE: Nitro models pusher Bobcat? - 4/28/2008 2:40:34 AM
    rifraff
    Status: offline
    thanks for the help Stick Jammer i sent Nitroplanes an E mail, will see what they say on monday ive never dealt with them before, let me say thanks again [)]
           Post #: 3163
