RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  126 127 [128] 129 130 131 132 133 134 135   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 5/1/2008 6:33:26 AM
    HobbyHut-RC
    Status: offline
    Ive just purchased a Bobcat 50 in Thailand - I payed 3'500 baht which is approx. $100 USD - I have started to build the bird after spending nearly 2 days reading this massive thread for good advise. I will be fitting the 301 retract system and I have a .46 size western UK racing engine for the power plant with Western UK racing tail pipe. Not sure if it will work but if it seems not practical I shall install my backup OS55AX. Im going to have a go at installing single servo for elevator, as it looks like a simple and effective conversion. This is my first jet type pusher plane and im hopping it will be a good introduction into model jets.
    _____________________________
    What goes up simply must come down!
    (in reply to tizer33)
           Post #: 3176
    RE: Nitro models pusher Bobcat? - 5/3/2008 12:14:21 AM
    Stick Jammer
    Status: offline
    quote:
    ORIGINAL: amcleod
    My 520W1 retracts arrived today, 19 days after ordering. Along with a few other small parts (props, etc) they cost me $168. Shipping came to $31, and excise duty (miraculously!) was $0. So a total of $199.
    I've never used these things before. How are they attached? Self-tapping screws directly into the wood rails? Or machine screws through into blind nuts behind? I like the sound of the second option best.
    Wood screws are fine.
    The more you fly, the more you buy.
    (in reply to amcleod)
           Post #: 3177
    RE: Nitro models pusher Bobcat? - 5/3/2008 12:19:29 AM
    Stick Jammer
    Status: offline
    quote:
    ORIGINAL: tizer33
    Thanks Stickjammer
    I already got the pipe to fit a 37mm exhaust hole spacing so that makes my choice for me - 55ax.
    Its the weston pusher pipe should work out ok i hope.
    I have got to get the front retract installed yet but am waiting to pick up a cheap nose leg as the local model shop want £47.50 or $90ish for robart one.
    Is a micro servo like the Hitec hs65mg ok for steering?
    Tim.
    Depends what you're flying from. I would not use a micro servo for grass as the nose wheel has the potential to easily strip the gears.
           Post #: 3178
    RE: Nitro models pusher Bobcat? - 5/3/2008 1:24:14 AM
    KnowCrashes
    Status: offline
    quote:
    ORIGINAL: Stick Jammer
    quote:
    ORIGINAL: tizer33
    Thanks Stickjammer
    Tim.
    We had trouble even using standard Futaba 3004 servos on the nose wheel. Just didn't have the power to turn the steering arrm to the nose wheel. We used a JR 126oz servo. Don't remeber the model # off the top of my head though. We have a second 'Cat under construction and will try a JR DS821 on that one.
    (in reply to Stick Jammer)
           Post #: 3179
    RE: Nitro models pusher Bobcat? - 5/3/2008 5:35:07 PM
    Stick Jammer
    Status: offline
    Original: KnowCrashes
    That's odd. A 3004 should have plenty of power for the nose wheel especially since it doesn't need a lot of movement and that gives the servo quite a mechanical advantage.
    (in reply to KnowCrashes)
           Post #: 3180
    RE: Nitro models pusher Bobcat? - 5/3/2008 10:26:38 PM
    tizer33
    Status: online
    so would you say any metal geared servo of 4-5kg torque should do it.
    I do fly off of grass but its a local turf field so you cant really get much smoother except bowling greens ect.. i am however heavy at landings.
    Tim.
           Post #: 3181
    RE: Nitro models pusher Bobcat? - 5/4/2008 1:19:12 AM
    Wingspam
    Status: offline
    Caiman.......
    I have about 25 flights on my Bobcat with the 46 ax. It flies the model just fine, but in saying that if I had to do it over again, I would put a 55 on it...
    Mine does not have retracts..
    Wingspam
           Post #: 3182
    RE: Nitro models pusher Bobcat? - 5/4/2008 1:37:07 AM
    caiman
    Status: offline
    Ok, thank's. I just bought a 55Ax to install it on my Bobcat.
    (in reply to Wingspam)
           Post #: 3183
    RE: Nitro models pusher Bobcat? - 5/6/2008 2:30:11 AM
    Stick Jammer
    Status: offline
    quote:
    ORIGINAL: tizer33
    Tim.
    I don't think metal gears are really necessary but a standard size servo would be much better than a mini.
           Post #: 3184
    RE: Nitro models pusher Bobcat? - 5/7/2008 10:36:59 AM
    cyborg1
    Status: offline
    I've read through the entire thread, but I haven't seen anyone post their results with a bobcat using a heli engine. I'm planning to install a tt .50 pro heli engine on mine. Does anyone have any experience to relate? keep the thread rolling....
           Post #: 3185
    RE: Nitro models pusher Bobcat? - 5/7/2008 6:03:35 PM
    caiman
    Status: offline
    Heli engines have better cooling than airplane engines, the problem might be that they are optimized to run at half throttle most of the time. But I think it might work well anyway.
    (in reply to cyborg1)
           Post #: 3186
    RE: Nitro models pusher Bobcat? - 5/7/2008 6:17:52 PM
    opjose
    Status: offline
    quote:
    ORIGINAL: AGR413
    I think you guys need to relax about the engine choice/speed deal. I used a doppler program on my original bobcat video and found the top speed to be 108 with a still breaking in engine set very rich on a 12x6 zinger. I have since put on a pitts muffler and switched to an 11x7 APC and it is much faster now. BTW my bobcat is without retracts. Others have mentioned the limitation for speed on this airframe has more to do with the airframe not the engine.
    This is by the way a tower .75. I have done the math earlier in this thread look for yourself.
    Yup, the T.H. 75 or the GMS hauls on this thing.
    Since I've switched out to an 8 pitch prop the jet guys have been very impressed with my little "cat".
    Build em'', fly em'', crash em'' and build more.
    (in reply to AGR413)
           Post #: 3187
    RE: Nitro models pusher Bobcat? - 5/7/2008 6:20:00 PM
    opjose
    Status: offline
    Yeah that's what I'm using on the nose w/o problems.
    While 45 degrees or more of stearing rotation in each direction is NICE, it is not needed to fly this plane
           Post #: 3188
    RE: Nitro models pusher Bobcat? - 5/12/2008 6:50:54 PM
