RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  131 132 [133] 134 135 136 137 138 139 140   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 7/26/2008 3:52:04 AM
    sbrackets
    Status: offline
    I understand what you mean about the push/pull nose gear. I've been wondering about that myself. Looks like Spring Air retracts are the way to go as they don't use a push/pull system on there gear. I believe a firewall retract mount is best suited for this model Prop-Jet.
    Please view post # 1686, Page 68 here in this forum. There are photos of a Bobcat with a Firewall mount retract installed. This model retract will provide a better sterring method then the Robarts model Push/pull system as the Spring/Air sterring controls are internal to the fuselage.
    View the Spring/Air web site for model 101- Firewall mount $149.00
    http://www.retracts.com/Retrax_100.htm
    < Message edited by sbrackets -- 7/26/2008 4:02:56 AM >
    (in reply to HeliTB)
           Post #: 3301
    RE: Nitro models pusher Bobcat? - 7/26/2008 5:07:03 AM
    HeliTB
    Status: offline
    Here's are pics of my issue with the front/noser gear retract with strut (2 pics to the left). My main retracts are fine as you can see in the pics (pics to the right).
    The issue is the pull-pull control arms can't go any further down the strut to clear the mounting rails. If you look close you can see the mouting in the pic to the far left.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    _____________________________
    Raptor v2 OS 37/Bobcat Jet OS .55 AX
    Extra 330L 25% SV26cc/SIG Kougar OS .46 AX
    (in reply to sbrackets)
           Post #: 3302
    RE: Nitro models pusher Bobcat? - 7/27/2008 8:58:50 AM
    Boomerang1
    Status: offline
    I used the firewall mount on mine with the steering servo on the retract unit.
    Refer post # 3249 on page 130. - John.
    Distributor for: Nothing! So my posts can be unbiased.
           Post #: 3303
    RE: Nitro models pusher Bobcat? - 7/27/2008 2:27:10 PM
    sbrackets
    Status: offline
    Hello Boomerang1
    Yes, That arrangment is a good idea to keep the servo close to the retract, I'm still in a pickle trying to figure this all out. I would really like to make use of the mounting rails that are alrady there and I would, but it's still the problem with the steering. I don't want to use the push/pull system. I want to have the steering system like your using.
    Looks like I'll hane to cut out the retract mounting rails and the most of one bulkhead and relocate the Wall mount retract to the foward bulkhead to make this all work correctly.
    I have added a couple of photos of my Bobcat and my idea of cutting out the center section of the aft retract bulkhead leaving only a plywood ring behind for reinforcement reasons. Then add & glue a piece of 1/4" thick plywood to the forward retract mounting bulkhead and install the firewall retract at this position with the servo attached if one like to do that option.
    Anyway that's my plan. I know it seems like it's a lot of work, but this is how it should have been designed from the beginning for steering reasons only.
    This is just my 2 cents worth.
    Click for fullsize
    Click for fullsize
    < Message edited by sbrackets -- 7/27/2008 2:56:46 PM >
    (in reply to Boomerang1)
           Post #: 3304
    RE: Nitro models pusher Bobcat? - 7/27/2008 6:25:28 PM
    RAMFlyer
    Status: offline
    If you have the access, what I did was laminate ply to the area under the control arms and then hollow grind the mount away for clearance. Hopefully the pictures are clearer than my description . This was a mockup I did before to make sure the idea worked before butchering the gear mounts in the airframe.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by RAMFlyer -- 7/27/2008 6:50:16 PM >
           Post #: 3305
    RE: Nitro models pusher Bobcat? - 7/27/2008 7:32:54 PM
    sbrackets
    Status: offline
    Hello Ramflyer
    Thanks for offering your ideas. I guess the bottom line is, theres no easy way to install a good steerable nose gear on this bird without a good deal of work in front of you
    All I know is that you better a your Dremel tool ready!
    (in reply to RAMFlyer)
           Post #: 3306
    RE: Nitro models pusher Bobcat? - 7/27/2008 8:52:24 PM
    HeliTB
    Status: offline
    Ramflyer...That's what I did in a sense. I used my dremel and made a trench for the steering arm to recess into. Worked out well.
           Post #: 3307
    RE: Nitro models pusher Bobcat? - 7/28/2008 1:47:59 AM
    HeliTB
    Status: offline
    Okay I have a question or poll if you will. What are you guys doing for the engine?
    Are you putting about 5 degrees tilt in it to compensate for the pitch up?
    Or
    Are you using trim to fix that?
    Reason I'm asking is if I tilt the front of the engine (tilt the prop side down). I will need longer screws for the back two screws of the engine.
    RamFlyer...What kind of retracts are those?
           Post #: 3308
    RE: Nitro models pusher Bobcat? - 7/28/2008 4:31:34 AM
    squidster
    Status: offline
    quote:
    ORIGINAL: HeliTB
    YES!! We flew ours without the downthrust at first. Takes a lot more runway to get it off the ground. With the downthrust, you will cut your runway usage by 1/2 to 2/3. It flys much better with the downthrust.
    Take a look at a BVM BobCat or KingCat witht the turbine.... they both have a good bit of down in them.
           Post #: 3309
    RE: Nitro models pusher Bobcat? - 7/28/2008 9:43:42 AM
    Boomerang1
    Status: offline
    sbrackets, the guy that originally built mine used the servo mounted on the retract because he made the noseleg retract forwards so a pull/pull setup would have made the cables go tight, not loose when the wheel retracted.
    I notice on yours the wheel retracts back so a pull/pull system would work fine. I did what HeliTB suggested on my other jet, dremmelled out a trough for the retracted steering arm. - John.
    (in reply to squidster)
           Post #: 3310
    RE: Nitro models pusher Bobcat? - 7/28/2008 12:12:03 PM
    sbrackets
    Status: offline
    I really am not familiar with how the Push/Pull cable system works. I have always use a 2-56 control rod for steering in the past. I understand how it works, but I don't have any experience with them. Just wondering about all that loose cable getting knotted up on something inside the fuselage during flight.
    Do you guys believe that I'll be OK if I order the retracts with the push/pull system for the nose gear? Rather then going through all the trouble of a firewall type like I was planning? I really hate to make this build more difficult then at has to be.
    Your advise would be greatly appreciated.
    P.S I would really HELP! if someone would post photos of their Push/Pull nose retract with the cables in place with the gear up, and the gear down so that I could view the cable arrangement.
    < Message edited by sbrackets -- 7/28/2008 12:18:30 PM >
           Post #: 3311
    RE: Nitro models pusher Bobcat? - 7/28/2008 12:43:27 PM
    HeliTB
    Status: offline
    sbrackets...Your request has been answered, LOL.
    Follow this link to another RCU forum with a nice pic of the Robart 520w1 steering setup. Post #14
    http://www.rcuniverse.com/forum/m_5826610/anchors_5826610/mpage_1/key_retract/anchor/tm.htm#5826610
    Here's another link as well.
    http://www.rcuniverse.com/forum/m_6075924/mpage_1/key_/tm.htm
    < Message edited by HeliTB -- 7/28/2008 4:40:46 PM >
           Post #: 3312
    RE: Nitro models pusher Bobcat? - 7/29/2008 1:28:05 AM
