RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Bobcat - 50
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 8/13/2006 12:18:27 AM
    papasmurf
    Status: offline
    I have the "ling cat" from avia-richmodel. It is extremely light weight as the bare airframe weighs about 12 oz. I am wanting the larger kee cat and have spoke with a vendor that is trying to get some in. Initial report was they are not set up for retracts despite the photos but then I was informed a while later that they were built with retracts. The specs are fairly similar between the avia-richmodel and nitroplanes as far as dimensions go. I am hoping the avia version comes out lighter than the listed weight as there is a 2 pound difference between the two. I never realized the nitro version had a glass fuse. Knowing how heavy chinese glass work is I am hoping the weights will be fairly close between the two. The AUW for the ling cat was 26 oz. on their site but I could easily see it coming in at 22 oz. or less without too much work so hopefully their other weight predictions prove to be a bit overstated as well. I would love to see some photos of this version after completion as well!
    (in reply to G-ROOKIE)
           Post #: 51
    RE: Nitro models pusher Bobcat? - 8/13/2006 5:15:20 AM
    H.Dale
    Status: offline
    Here's several pictures. They were taken with a cell phone so they are not as clear but it will give anyone interested an idea of what it will look like with a turbine.
    Hal
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 52
    RE: Nitro models pusher Bobcat? - 8/13/2006 5:47:19 AM
    JasonP
    Status: offline
    Hal
    Hal
    Very cool setup.
    Is yours the 51" model? Seems to be a fairly good size.
    I wonder if I could power one with a Mark II.
    How about a few picks of your setup.
    JasonP
    (in reply to H.Dale)
           Post #: 53
    RE: Nitro models pusher Bobcat? - 8/13/2006 3:53:46 PM
    H.Dale
    Status: offline
    Jason
    Mine is the 51" model. It is much bigger than I thought. I think you could power it with a MW54 or a P60. It would be extremely fast. It is bigger than the Savex L-39 and I have heard that several people have put a 54 on them.
    I will put some more pictures out when I get further along.
    Hal
    (in reply to JasonP)
           Post #: 54
    RE: Nitro models pusher Bobcat? - 8/13/2006 4:25:52 PM
    SJN
    Status: offline
    Neat!
    At first glance, i thought that the turbine looks so small.
    I think it will fly great on the MW-44
    _____________________________
    Sonnich Johannesen
           Post #: 55
    RE: Nitro models pusher Bobcat? - 8/13/2006 5:09:53 PM
    rcguy!
    Status: offline
    Folks,
    MY spin on "smaller" turbine (MW44) powered planes.
    They get small real fast. My Reaction 44 (72% size R54) has a 56" W/S and 750 square inches of wing weighing 9 1/2 pounds dry. I'm CONSTANTLY moving the throttle up and down to keep it at a reasonable speed and visiblity. This 51" W/S at low to mid 600 squares will cook with even the 8# MW44. Keep it below 9 pounds dry and you'll have a ball! "If only it had retracts!"
    More pictures Hal!
    Dave Rigotti
    (in reply to SJN)
           Post #: 56
    RE: Nitro models pusher Bobcat? - 8/14/2006 9:31:22 PM
    B58
    Status: offline
    So, anybody fly one yet? Bob
    (in reply to rcguy!)
           Post #: 57
    RE: Nitro models pusher Bobcat? - 8/15/2006 12:02:04 AM
    Joe Kelley
    Status: offline
    Hi Dave, I know you do have experience with this size plane and the wren 44 turbine. I would really like to see this model in a 800 to 1000 sq' size for a 44. It sure is sharp and the price is right. We got a few coming in out here so we'll see!~)
    JOe
    quote:
    ORIGINAL: rcguy!
    Folks,
    More pictures Hal!
    Dave Rigotti
           Post #: 58
    RE: Nitro models pusher Bobcat? - 8/15/2006 1:57:39 AM
    mugenkidd
    Status: offline
    papasmurf or anybody else where did you get the "ling cat" from. I need a little .46-.90 size low stre$$ beater jet. But retracts would be a nice option. If I don't here something soon about the ling cat I'll probally just order one of the baby bobcats.
    www.westside-rc.org
    (in reply to Joe Kelley)
           Post #: 59
    RE: Nitro models pusher Bobcat? - 8/15/2006 2:30:55 AM
    rcguy!
    Status: offline
    quote:
    ORIGINAL: Goekeli
    JOe
    quote:
    ORIGINAL: rcguy!
    Folks,
    More pictures Hal!
    Dave Rigotti
    Joe,
    Yes indeed! 800 squares great for grass ops. 850 a bit better! With the newer MW44 at 10# thrust...OH BOY!
    I heard a rumor that there is a "infant boomerang" in the works for the MW44 sized turbines for this Fall/Winter. Hope Alan keeps it sized right in the 750 to 850 range.
    Dave Rigotti
           Post #: 60
    RE: Nitro models pusher Bobcat? - 8/15/2006 3:42:03 AM
    papasmurf
    Status: offline
    The "ling cat" is 32" wingspan. I got it at www.ejf.com
    I have toyed with the idea of robart 1/2A retracts but if you use all the servo location provided that comes to between 6 and 7 servos. The plane is amazingly light and would work really well as a pusher or EDF. The larger version with the retracts is not available....yet.
           Post #: 61
    RE: Nitro models pusher Bobcat? - 8/15/2006 4:27:57 AM
    G-ROOKIE
    Status: offline
    Go with the Bobcat you want be soory.
    (in reply to mugenkidd)
           Post #: 62
    RE: Nitro models pusher Bobcat? - 8/15/2006 4:47:37 AM
    topper5
    Status: offline
    well guys i got mine today and the first thing i did was break out the chainsaw, ripped open one wing and this is what i got, allot of ribs,the rear spare, and more ribs, the wings are built for speed, i haven't seen any retract yet so here is my first wing a with 605 spring-air retract rough'et in, in the nose i will have nose gear retract forward it just seems like the best idea with the empty space up there, well back to the other wing.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by topper5 -- 8/15/2006 4:55:14 AM >
