RE: Nitro models pusher Bobcat?
Tower Hobbies
Logged in as Guest
Users viewing this topic: agoodman
  Printable Version
More Resources on the
Bobcat - 50
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Jets >> RE: Nitro models pusher Bobcat?
    Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
    Login
    RE: Nitro models pusher Bobcat? - 8/16/2006 3:34:59 AM
    mugenkidd
    Status: offline
    Now the website says $169 and both colors are sold out.....snooze u loose
    _____________________________
    www.westside-rc.org
    (in reply to jetflyer)
           Post #: 76
    RE: Nitro models pusher Bobcat? - 8/16/2006 4:30:01 AM
    G-ROOKIE
    Status: offline
    www.raidentech.com is showing sold out but the price is still $129.00.
    (in reply to mugenkidd)
           Post #: 77
    RE: Nitro models pusher Bobcat? - 8/16/2006 5:22:23 AM
    booker-RCU
    Status: offline
    Here's what I’ve done for the elevator. It's a fairly simple way to go. You'll notice the servo lead is coming out the bottom of the elevator but will be inside the boom and run down to the wing then into the fuse. The servo sticks’ out the bottom of the elevator about 1/4 inch but will be covered with a plastic faring and painted white just like the real Bobcat when larger servos were installed in the elevator. These fairings are available from DreamWorks. The Servo is a GWS MICRO 2 BB METAL GEAR SERVO it's rated at 75oz in Torque.
    I'm continually impressed with the construction of this acft.
    Galen
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    (in reply to G-ROOKIE)
           Post #: 78
    RE: Nitro models pusher Bobcat? - 8/16/2006 5:36:05 AM
    mugenkidd
    Status: offline
    great pictures booker.
    Question for the guys thinking of using a pusher prop set-up. Does anyone make a pusher prop with a high pitch, and I'm guessing that your probally limited to a 10in diameter prop. I'm looking on the tower website and I'm only seeing the highest pitch prop being a 10x8 pusher, seems like if I guy wanted to run somthing bigger than a .46 or .50 then you would need a higher pitched prop.
    www.westside-rc.org
    (in reply to booker-RCU)
           Post #: 79
    RE: Nitro models pusher Bobcat? - 8/16/2006 6:11:10 AM
    CARS II
    Status: online
    I have looked on every prop maker's web pages and we are stuck with the 10-8 as the highest pusher pitch prop for the 60s or the 90s and that is what really stopped me from getting an airplane, hard to find a suitable prop for the 60, 90 size engines
    CARS II
    To infinity and beyond...........
           Post #: 80
    RE: Nitro models pusher Bobcat? - 8/16/2006 6:53:43 AM
    topper5
    Status: offline
    tower sells props all the way up to a 22x18 zinger, apc has a 14x6, and if clearance is the factor you can all-ways go with a tri blade pusher.
    (in reply to CARS II)
           Post #: 81
    RE: Nitro models pusher Bobcat? - 8/16/2006 4:13:32 PM
    gregmax
    Status: offline
    Hey the Bobcat 50 is available in the UK, the Chinese manufacturer pointed me to the UK supplier.
    It's an absolute bargain at £185 + £10 shipping a total of $351 (at an exchange rate of $1.8 to the UK pound )
    http://s147682260.websitehome.co.uk/default.htm
    Nitroplanes wont ship internationally and Raidentech quoted me shipping then cancelled my order and said "unable to ship oversize item to international"
    Now trying to find a shop in HK that will ship to me!
    Greg
    (in reply to topper5)
           Post #: 82
    RE: Nitro models pusher Bobcat? - 8/16/2006 4:27:01 PM
    B58
    Status: offline
    We must have got a pretty good deal on them here then. The box is not really very large, so don't think it would be oversize. I have a yellow and blue one and just need to figure out which will be the easiest to see. It will get a turbine, and the other a glow engine. Bob
    (in reply to gregmax)
           Post #: 83
    RE: Nitro models pusher Bobcat? - 8/16/2006 7:52:25 PM
    kmtranmd
    Status: offline
    Tower carries the apc 10x8 pusher and zinger 11x8 pusher that you can use for 60 and 90 size motors accordingly.
    GI Doc
    (in reply to B58)
           Post #: 84
    RE: Nitro models pusher Bobcat? - 8/16/2006 8:40:24 PM
    rcavi8ter
    Status: offline
    Damn I tried to order mine from Raidentech before they bump the price but no way to order an out of stock aircraft. Anyone have a yellow one they want to sell?
    Chris Puckett
    (in reply to kmtranmd)
           Post #: 85
    RE: Nitro models pusher Bobcat? - 8/16/2006 9:35:30 PM
    Zagzoo
    Status: offline
    Found a place you can still order them for $119+$30 (shipping):
    http://bizrate.lycos.com/robotic_radiocontroltoys/robotic_radio_control_vehicle_type--aircraft_jet/products__att583656--468584-__keyword--rc%20gas.html
    woot! just got me one!
    (in reply to rcavi8ter)
           Post #: 86
    RE: Nitro models pusher Bobcat? - 8/17/2006 1:58:07 AM
    bahamadude
    Status: offline
    Not trying to swithc the topic but if anyone can help i would be thankful
    Looking for s itw who sells this plane in the US :
    http://fly-model.com/cp_detail.php?id=19149&nowmenuid=1243&cpath=0261:&catid=0
    its the yak 54 3D
    (in reply to Zagzoo)
           Post #: 87
    RE: Nitro models pusher Bobcat? - 8/17/2006 4:29:51 AM
    Crazy4Flight
    Status: offline
    quote:
    ORIGINAL: booker-RCU
    Here's what I’ve done for the elevator....... The Servo is a GWS MICRO 2 BB METAL GEAR SERVO it's rated at 75oz in Torque.
    Galen
    My plan was to use a Hitec HS-125MG or HS-5125MG thin wing servo both metal gears but the 5125 is digital and 49 oz/in a@ 6.0V. http://www.hobbyhorse.com/hitec_hs5125mg.shtml
    But having two HS-225BB instock providing 65 oz/in I elected to use what I had on hand. Also I would not have to drill through the tail boom to feed the servo leed. servo pockets were about 1/16" short on length.
    Radio is a Futaba 9CA, I will mix elevator to an Aux channel to handle reversing and centering and end point issues. No I did not split the elevator like the BVM's jets.
    Rudders very thick I plan to counterbore pockets and used a post type horn.
    ONE MINOR PROBLEM: The right wing was not assembled correctly. The layers of wood were not placed right. The servo pocket was tight and the hole for the landing gear is off center. Well I trimmed the wing skin to get the gear in place the bent the gear (axel) back to give it 1-2 degress of toe in. The left wing gear needs to be tweaked on the toe in.
    Still build quality is better than expected.
    Bob
    [image][/image]
    added pictures of fuse interior..
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by Crazy4Flight -- 8/17/2006 4:58:10 AM >
