RE: post a pic of your rc tank
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: post a pic of your rc tank
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: post a pic of your rc tank - 9/19/2006 2:19:18 PM
titan20
Status: offline
Hey Dinodog, I really like the 1:12 scale Abrams or "Panzer" or whatever it says on ebay it is. I'm glad to see someone fix one of those up, and its good to know it has potential. How does it run? Did it run decent with the stock electronics, or were they complete junk? Does it have any suspension at all. That tank combined with the Tamiya Hummers is an awesome sight. Makes me want a Tamiya Hummer. . .
(in reply to titan20)
       Post #: 51
RE: post a pic of your rc tank - 9/19/2006 11:50:59 PM
dinodog
Status: offline
Hi Guys, I believe that all insignia should be historically correct although some discretion being the better part of valour could be shown in public places where people would not expect to see political material of any kind. Scale model conventions and Reenactment shows is where you would and should see them. Tanks for Tankers lol! Hi titan20 the Hailaing is still my favourite model at the moment and I am still pleased that I bought two. One for spares and one for conversion. Think of it as a bodyshell and that should justify the cost. If any Tank was tailor made for conversion then this is it! Oddball scale for Tanks but a perfect match for 1:12 Plan b Toys action Figures and Tamiya 1:12 Hummers which I must add are the mutz nutz! Electronics are the infamous bt500r, similar to Heng Long, it will run OK for a while but don't hold your breath. A Tri Pact Speed control is cheap and will fit across chassis. Suspension needs freezing on the 1st and last two wheels, or upgrading which should be fairly easy oh yes a Track tensioner must be added with basic shims on sprung front axle. Tracks are rubber but stay on really well now mods are in place. 9.6v gives just below scale speed but the Tri Pact Speed Controller can take 14.4v.....Well worth it is all I can say because I have a 1:12 scale Tank with airsoft and space for paintball and camera if I so wish for less than $400 including new Futaba 4 Channel etc etc.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by dinodog -- 9/20/2006 12:29:24 AM >
_____________________________
THE FOUR Fs. FIND THEM, FIX THEM,
FLANK THEM, err.........FIGHT THEM!
       Post #: 52
RE: post a pic of your rc tank - 9/20/2006 12:22:22 AM
dinodog
Status: offline
Some recent shots, I have gone 1:12 crazy!
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to dinodog)
       Post #: 53
RE: post a pic of your rc tank - 9/20/2006 2:18:30 AM
navspook
Status: offline
Proulxlaw and Razataz:
I got it used from a gentleman in NC. He put it together from a kit from www.rcarmory.com
I had to refit it (replace a few things, re-wire, etc) because it was already about 8 yrs old. It's very powerful, heavy, and behaves much like the real thing -- esp going through tall weeds/grass, through creeks, that sort of thing. I'll be able to test it in snow in another week or two.
But, man, it's really fun to mess with. I still need to put a sound module in it, re-work the turret (the original owner engineered a .22 cal blank mechanism with separate servo to shoot).
I might go to 1/6 scale after this one. I'm really stuck with the larger scale now.
Cheers...
(in reply to razataz327)
       Post #: 54
RE: post a pic of your rc tank - 9/20/2006 2:23:10 AM
navspook
Status: offline
You guys have some really fantastic tigers! Looks like original equipment when you use black and white photography.
(in reply to navspook)
       Post #: 55
RE: post a pic of your rc tank - 9/20/2006 8:51:41 AM
Plastic scouser
Status: offline
Hi Dinodog have you seen these from Mcfarlane toys they are meant to be 1/12 scale http://www.starstore.com/acatalog/Starstore_Catalogue_McFARLANE_S_MILITARY_SERIES_1_ACTION_FIGURES_4744.html
Cheers Ian
       Post #: 56
RE: post a pic of your rc tank - 9/20/2006 6:22:23 PM
dinodog
Status: offline
Hi Ian, I think they measure 7 Inches in height which makes them about 1:10 I think. 1:12 scale equates to 1 Inch to 1 Foot so Action Figures need to be 6 inches tall to fit the Hummer. Mcfarlane Figures are a bit too big but pretty close!
(in reply to Plastic scouser)
       Post #: 57
RE: post a pic of your rc tank - 9/20/2006 8:02:10 PM
proulxlaw
Status: offline
I agree on the bigger scale stuff. I have an Ultimate Soldier 1/9 scale M1A1 and it's pretty cool. I'll see if I have pics of it to post.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by proulxlaw -- 9/20/2006 8:32:42 PM >
       Post #: 58
RE: post a pic of your rc tank - 9/21/2006 8:37:09 AM
dinodog
Status: offline
Hi proulxlaw, what a fantastic looking 1:9 Tank! Bigger scale stuff seems to be gaining popularity fast! Plenty of room inside for mods and great looks and performance when in the field! I know I'm biased but I think Tamiya should release more 1:12 stuff to suit the Hummer, but I would say that wouldn't I!
(in reply to proulxlaw)
       Post #: 59
RE: post a pic of your rc tank - 9/21/2006 9:26:02 AM
Rathead123
Status: offline
Hey Dino that 1-12 scale tank will move on on 14.4v's, Ive been running one that way for a while. Got camaras and stuff on it. I put threaded screw, nuts on the front axel for track tension. Also noticed turrent rotation motor gearbox is the same as a henlong, as mine is burned up need to get one. Did you do away with the relay board and wire direct to the motors on the conversion? Mines still on the stock vcc but transfers to 14.4 on the relay board. 9.6 for everthing else. They make good projects.
       Post #: 60
RE: post a pic of your rc tank - 9/21/2006 2:30:11 PM
Turbobearcat
Status: offline
I only wished I could have bought one of the those 1/9 scale Abrams M1A tanks..I went back to get one and they were all GONE!!!!
(in reply to Rathead123)
       Post #: 61
RE: post a pic of your rc tank - 9/21/2006 4:24:14 PM
dinodog
Status: offline
Hi Rathead123, great news that someone else has seen the light! First off I got the volts to the Turret motor down to around 5v, I did this by taking a 5v "tap" off my main batt pack. I think it will last a bit longer lol! I also have 5v for radio this way. I was sticking to 9.6v for the drive motors as this is normally the max for a geared 300 type motor but if you are getting good results and a reasonable motor life then I will try 14.4v as well! I tried it at 14.4v for a few short runs and it certainly does fly! Then I lost my nerve and went back to 9.6v! I do have two spare motors! ..... I have included some old pics of when I was working on the Tank, the Tri Pact Speed Controller plans are available at http://www.rctankcombat.com/articles/speed-control/ if you haven't found it already!
I wired mine with 4 sockets and a connector strip but you could cut down on weight and use heat shrink over the directly connected wires to the Auto standard type spdt relays. I used a connector strip to make the diode loop because I had one but a fibre board or direct soldered wires would be lighter. No trouble with standard gearbox yet how is yours bearing up on 14.4v?
Click for fullsize
Click for fullsize
< Message edited by dinodog -- 9/21/2006 4:26:31 PM >
(in reply to Turbobearcat)
       Post #: 62
RE: post a pic of your rc tank - 9/21/2006 4:37:10 PM
titan20
Status: offline
Many, dinodog, you guys are really making me want one of those 1/12 scale Abrams to convert, plus a Tamiya Hummer to go with it! This would probably give me another opportunity to try my new successful Scorpion esc, and Futaba radio combination (or maybe two Scorpions, two batteries, and a 4-channel radio so I could maintain a lot of the "extra" functions).
