My battleaxe is built! But I need engine help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> My battleaxe is built! But I need engine help
Page: [1]
Login
My battleaxe is built! But I need engine help - 8/7/2006 1:03:37 AM
vwtrey
Status: offline
Well, I'm finished building my battle axe. It was a very fun kit to build, even for someone as novice as me. I enjoyed it, and would like to do another, sometime soon. Thanks Alex, its going to be a good one!
I'm having problems with my OS .15la. I did the one tank break in, running it rich. Now I'm trying to get it tuned some, but having problems. It runs good, up until about half throttle, and past that, It dies. None of the adjustments with the carb seem to be helping much. I sealed up the back plate cover, replaced all the fuel lines, but still, no luck. Anyone care to offer some advice? Thanks!
trey
       Post #: 1
RE: My battleaxe is built! But I need engine help - 8/7/2006 3:32:21 AM
RC MANIAC119
Status: offline
IT's running too lean........open that needle valve until you can get it to transition to high end!
_____________________________
RC MANIAC-PRO BRO 1900-AMA# 95841
(in reply to vwtrey)
       Post #: 2
RE: My battleaxe is built! But I need engine help - 8/8/2006 4:25:52 AM
Fred420
Status: offline
Glad to see you got an Axe. You will love it. Maniac has it right, just keep opening up the high end. Are you going to cover the wing or go bare?
Fred420
Dave "that red-headed stepchild" Davis
(in reply to RC MANIAC119)
       Post #: 3
RE: My battleaxe is built! But I need engine help - 8/8/2006 12:32:38 PM
Clean
Status: offline
I don't see enough foam under the tank. On my HOR it acted the same, good up till half throttle, of course it looked like I had a milkshake in my tank at that point.
From Somewhere near Parkville, Mo.
William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
(in reply to Fred420)
       Post #: 4
RE: My battleaxe is built! But I need engine help - 8/8/2006 1:29:45 PM
vwtrey
Status: offline
Thanks guys, I will try running it today, If I get time, and get it tuned some. I didnt notice any foam in the tank, but I might put some thicker foam under it, just to be safe. Not sure what I am going to do with the wings, I kind of like it the way it is, but who knows.
It was a really nice kit to build. Very enjoyable, and the instructions were good, even for a new guy like me. I can't wait to get it running good, and go for some flying!
trey
(in reply to Clean)
       Post #: 5
RE: My battleaxe is built! But I need engine help - 8/8/2006 9:44:37 PM
flyinrog
Status: offline
the fuel wont hurt the foam, but after a few flights it wont be too pretty, and you cant wipe the residue off the foam like you could with covering...Rog
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
       Post #: 6
RE: My battleaxe is built! But I need engine help - 8/8/2006 11:27:40 PM
vwtrey
Status: offline
also, my engine did not come with a muffler gasket. Seems to me like it needs one, but I didnt know if it did or not, being a smaller engine. Does it need one?
trey
(in reply to flyinrog)
       Post #: 7
RE: My battleaxe is built! But I need engine help - 8/9/2006 1:16:19 AM
Clean
Status: offline
Take the muffler off, put a thin film of Copperseal RTV on the clean muffler and let it set up for 15 minutes (or follow the instructions) then mount the muffler back on. Then use the RTV to seal the backplate, carb mount and anything else you can think of.
RTV is your best friend, you best get familiar with it.
       Post #: 8
RE: My battleaxe is built! But I need engine help - 8/9/2006 2:23:22 AM
Alex Treneff
Status: offline
Trey,
The Battle Axe looks great! You'll love it even more in the air.
If you follow the engine procedure outlined here you shouldn't have too many engine problems.
Use the foam that was included in the kit. Make sure the tank is strapped down real tight.
Do not use any silicone or other sealers anywhere but the backplate. The muffler and crankcase are machined perfectly flat. If you have the muffler tight you won't need a gasket or sealer. The O.S. needle is also high quality and needs no sealants.
Be sure to use only A3 glow plugs and good fuel (such as Cool Power Heli). Be sure you only put RTV around the flat lip of the backplate, not clear inside the engine.
It will take a handful of flights for the engine to really loosen up and hit 17,500. When it does you will have one sweet-flying airplane!
Good luck,
Keep us posted.
Alex Treneff
< Message edited by Alex Treneff -- 8/9/2006 2:24:33 AM >
Alex Treneff
TreneffRC - Team Battle Axe
       Post #: 9
RE: My battleaxe is built! But I need engine help - 8/9/2006 2:43:30 AM
vwtrey
Status: offline
Well, just got done from the flying field. What a blast!!!!! That thing flies great. I'm a new pilot, this is my second plane. I did not have dual rates set up on it, or expo. That made it even more fun than what it would have been. Got the engine running pretty good. The os book said use a 8x5 for break in, and I also used it tonight, but I need to go down to a 8x3, like Alex recommends. I wanted to see what it would do in a stall, that was fun too! Ah man, I wont sleep tonight!!!
trey
(in reply to Alex Treneff)
       Post #: 10
RE: My battleaxe is built! But I need engine help - 8/9/2006 3:34:07 PM
rrh
Status: offline
vwtrey, Nice Battleaxe, I'm sure you'll love it
I see you are just up I-25. There is some good monthly and sanctioned SSC combat in the Denver area. Bring your Axe down and mix it up with us There will be some other Axes there as well as Avengers and SPADs. Airpark Elite has a sanctioned NPS event Sept 23rd. We try to fly club combat the first Saturday of the month - year round (but not to conflict with sanctioned events) - at Mile Hi RC Club. We'd love to have you in the furball
r
Randy Hodges
RCCA 745
       Post #: 11
RE: My battleaxe is built! But I need engine help - 8/15/2006 3:12:01 AM
vwtrey
Status: offline
Just an update, I had the chance to fly my Battle Axe again Sunday evening. This time, I had a 8x4 prop on it, set up expo, and dual rates. The wind was about 15mph. It flew great! It is so much fun to fly, I usually dont want to land. And I dont have to land often, that thing doesnt like to use fuel. I'm really excited with it. I'm turning about 16k rpm, which is ok by me.
Randy, I might have to come down and watch you guys fly sometime. I dont think anyone would want me causing mid-air collisions, and I think I probably would. I would try my hand at it, but only after I learn to fly better. Its only been about 4 months for me.
(in reply to rrh)
       Post #: 12
RE: My battleaxe is built! But I need engine help - 8/15/2006 3:22:18 AM
RC MANIAC119
Status: offline
Don't be afraid..........just jump in there and fly a few rounds!! There's no way you can "Cause" a midair in combat..in fact I would bet you........ that if deliberately tried to collide with your combat opponents........all you would manage to do IS CUT SOME STREAMERS!!!!
Go for it and enjoy..you won't regret the sensation, and the adreniline!!!
       Post #: 13
RE: My battleaxe is built! But I need engine help - 8/15/2006 3:20:08 PM
rrh
Status: offline
vw, mid-airs just happen - nobody causes them Get out and practice, we probably won't get together until the event at Airpark Elite on Sept 23rd. I can't make that one so the other pilots would gladly welcome your streamer
4 months? You are ready to chase streamers I went straight from trainers to combat. When it comes to flying something other than a combat plane, I don't ROG or land very well but I fly pretty good
Practice all you can and learn what your plane will do.
r
Randy Hodges
RCCA 745
       Post #: 14
RE: My battleaxe is built! But I need engine help - 8/22/2006 9:29:09 PM
