whogdriver
FL, USA Status: offline
Ok guys, here's the inflight video. You will see some minor glitching of the camera pod servos, this is due to a less than satisfactory camera pod RC receiver - a Hitec 4MG, we plan to replace it. Also there is some minor video noise in places as we did not have the video receiver in an optimum position when we flew behind our cars. But you can get a good idea what this setup will be able to do once it is refined. Comments and suggestions are welcome. To answer the question about joining the horizontal stabs, you can see in the video there is very little relative movement between the stabs while flying. It also allows each fuselage to be flown as a normal Twinstar as we have two sets of normal wings for it, the center section allows it to become the Quadstar. I think it looks similar to a Burt Rutan design. The two receivers do make wiring simpler but also add a degree of redundancy or safety. http://video.google.com/videoplay?docid=-269250534341891571 The Google description says 306 degree pan, that's a typo, should be 360, it can spin around all day long if that's what you want. Whog
