plasticizer
IL, USA Status: offline
Ohhhhhh the UPS woman delivered el coro today. Wooohoo I said. The 4 boxes were a bit crunched on the corners, but they use a wrap around end on it, so the coro was fine. Basically, they just roll the ends of the box into a square tube and tuck it in on each end. Then I took a look at the packing list. Oh oh.....looks like Judy led me down the path. My original hunch about the price not being right was correct. It was indeed too low. The first quote I got from Stephanie was in the ballpark. Apparently after I hung up with Judy, someone else there with their glasses on and a good night's sleep took a look at the order and said....woaaa....that isn't right!! So they corrected it.....without any phone call to me about it. So this is what it comes down to cost wise as of Oct/06 as per their packing list. Cutting charge is $2.95 per 4ftx8ft sheet. I had 12 sheets, so it was $35.40 in cut charges. 4 mm coro in white = $0.2128125 per square ft. / $6.81 per 4x8 sheet (before cut charges) 2mm coro in white = $0.4521875 per square ft. / $14.47 per 4x8 sheet (before cut charges) Shipping to IL in 4 boxes was $11.38 UPS Cost BEFORE shipping charges, but INCLUDING cut charges = $0.305 sq ft for the 4mm, $0.544 sq ft for the 2mm. The 2mm is quite a bit more expensive, more than double the 4mm price. So in the end...Stephanie wins with the most accurate quote. Yeaaaa Stephanie.
