sknx
IL, USA Status: offline
I'm new to IMAC and I might get it wrong but I do not understand what means rudder in wrong direction and where you zero a flick. The regular snap roll is just elevator and rudder, no matter which direction. For a CW spinning prop and positive maneuver left rudder wil make the cone wider and faster, right rudder will tighten the cone but the autorotation it's slower. No matter the side, both are autorotational maneuvers. If ailerons are applayed with rudder, as far as I know, it's called accelerated snap roll. Going back to judging, are you zero a snap if no ailerons are applyed or ailerons are reversed to rudder ? 10X
