inroad-RCU
Joined: 11/12/2002 From: British Columbia Status: offline
Reputation for a radio system can be quite localized,someone mentioned Royal radios were available kit or factory built.We had some awful homebuilts around and then you couldn't give away any,factory or homebuilt.I still have an 8 channel Royal open gimbal built from a kit,had to get Pete Waters to put it on FM and Ham band a couple of years ago to keep it legal.No radio related failures since it was built in 1978.Some things like a 4 position flap switch,dual throttles I wish I had on my JR 8103,also every function and trim is on a deans plug.you can reverse anything by reversing the plug,also plug any function into any stick,slider or switch.also has dual rate and exponential,the expo is the smoothest I have seen,no way to make it jump.It seems that having a very good product is only a small part of commercial success,Royal fell to cheaper mfg process and marketing
