BlueMonster
WA, USA Status: offline
The bracket that hangs down off the rear and the servomount that is mounted to the bracket was made out of aluminum. You can buy it in 10' lengths at Home Depot for under $10, i always have a selection of the stuff, i use it for all my projects. If you have a brazing torch, you can heat the aluminum and it will bend and twist like butter. That's how I made the rear system. The rudder and pivot are brass sheet and brass tube, brazed (soldered) together. I pick that stuff up at my LHS, always have a selection of that around. The pontoons are syrofoam with plastic bottom, made by GWS. Make no mistake, they are the cheapest you can get. If you can get some nicer ones, do it, but these work fine.
