Rescue boats
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Boats General Discussion >> Rescue boats Page: [1] 2   next >   >>
Login
Rescue boats - 8/8/2006 5:44:59 AM
BlueMonster
Status: offline
So I was inspired by a pic in RC Boat magazine of a rescue boat on pontoons. I went out and bought some, and used all the gear from an airplane kit for power. I brazed up a rudder system as well. Tomorrow I'll finish the body and paint it up, next day it hits the water for testing, then I need to figure out the actual retieval system.
What do you think?
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Rescue boats - 8/8/2006 6:13:53 AM
NitroRunner
Status: offline
pretty cool, what kind of retrieval system are you going to use?
_____________________________
Is it..? I think its.. Oooh yea its broken...$%^&
(in reply to BlueMonster)
       Post #: 2
RE: Rescue boats - 8/8/2006 6:20:17 AM
BlueMonster
Status: offline
I have no idea! I was hoping others might share thier ideas.
(in reply to NitroRunner)
       Post #: 3
RE: Rescue boats - 8/8/2006 8:19:06 AM
LtDoc
Status: offline
Looks like an interesting boat. As for a retieval boat, I think I'd try making it a 'pusher', not a 'puller'. Putting the rescued boat in the propwash would also contribute to extra 'drag', wouldn't it? Maybe not much, but some.
- 'Doc
       Post #: 4
RE: Rescue boats - 8/8/2006 8:43:26 AM
BlueMonster
Status: offline
The prop on the rescue boat will be at the rear. Did you mean the rescue boat should use a pusher system, or that it should push vs. pull the dead boat? I don't know anything about setting one up, only that I should probably have one and I was able to put it together really cheap.
(in reply to LtDoc)
       Post #: 5
RE: Rescue boats - 8/8/2006 8:05:09 PM
LtDoc
Status: offline
Sorry, should have rephrased that just a little. The 'push'/'pull' thing refers to the way the rescued boat is moved, not the way the retrieval boat is powered. The 'drag' I was refering to would be from the prop-wash of the retrieval boat blowing against the 'dead' boat. Thinking about that again, there probably wouldn't be that much drag but who want's any that you don't have to have? Putting a 'knee' on the front of each of the floats ought'a work fine. (More 'odd' terminology! If you push with it, it seems like it ought'a be called a 'foot', not a 'knee', doesn't it? Don't ask me, I don't know why, but it's a "knee".)
- 'Doc
       Post #: 6
RE: Rescue boats - 8/8/2006 11:38:37 PM
BlueMonster
Status: offline
Okay, got it!
The motor on the rescue boat is a pusher, prop is in the rear, so the rescued boat should effect it at all. I don't quite understand the knee you refer to though, is there an example of it somewhere?
(in reply to LtDoc)
       Post #: 7
RE: Rescue boats - 8/9/2006 3:45:22 AM
LtDoc
Status: offline
"Knee" refers to a vertical pushing surface/structure. Commonly found on 'towboats' pushing barges on rivers (several pictures of such boats can be found on this forum). 'Pusher' does not refer to the motor on the retrieval boat. It refers to how the retrieval boat moves the 'dead' boat, it pushes it instead of pulling it with a tow line. If the retrieval boat pulls the 'dead' boat, the prop wash from the retrieval boat will end up pushing the dead boat backwards to some extent. Wouldn't matter if the motor on the retrieval boat was a 'pusher', or a 'tractor' type air moving motor. Using your retrieval boat as a pushing vessel instead of a pulling vessel would mean that the prop wash would not 'blow' back onto the dead boat and contribute more drag to the whole procedure since the dead boat would be infront of your retrieval boat, not behind it where the wind from the motor is blowing.
- 'Doc
       Post #: 8
RE: Rescue boats - 8/9/2006 3:50:57 AM
BlueMonster
Status: offline
Cool, I think my setup will work well then. I'll try to find some pics for ideas on the retrieval system. The boat will be done this evening, I'll post pics in a little bit...
...and don't laught, I made it ugly on purpose!
(in reply to LtDoc)
       Post #: 9
RE: Rescue boats - 8/9/2006 5:55:58 AM
BlueMonster
Status: offline
Okay, it's dark outside, and I just came back from the beach for it's maiden voyage. It was flawless. I think I might make a more aggressive rudder, but we'll see. It was awesome, I ran it til the battery died.
What do you think of the final version?
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by BlueMonster -- 8/9/2006 6:01:54 AM >
       Post #: 10
RE: Rescue boats - 8/9/2006 1:28:20 PM
CadillacETC2000
Status: offline
heck thats pretty good !
and with more power you can just drive rite over sholes and what not
Pity , with all my extra cash , just waiting to line someone''s pockets.
       Post #: 11
RE: Rescue boats - 8/9/2006 11:03:50 PM
BlueMonster
Status: offline
Yeah! The idea is to drive right over my Vee when it dies, but I might just run this by itself once in a while. It's a little slow, and steering could be a little crisper, but it is easily controllable and dependable, so it'll do it's job.
I couldn't find any pics of an actual retrieval system, so still working on that. Gonna float them both in the tub together and see if something dawns on me when I see them together.
(in reply to CadillacETC2000)
       Post #: 12
RE: Rescue boats - 8/10/2006 3:23:01 AM
Dave trimmer
Status: offline
I'm an air plane guy with little boat expierience but if you put small chicken wire instead of just ply wood on the front to reduce drag, and then just push it. or put lage strong magnets in each boat and drive by, lastly tie a small rope or net between yours and a friends boat and catch it like a butterfly net, hope this helps.
a minute of perfection was worth the effort. A moment was the most you could ever expect from perfection. - chuck Palahniuk
       Post #: 13
RE: Rescue boats - 8/10/2006 4:17:23 AM
NitroRunner
Status: offline
i like the tennis ball/ float way, and the magnet way. The float idea is to have a tennis ball or other floating object on a fishing line or string attached the the back of your boat, then you circle the dead boat 3 or 4 times and start to drive away and it will attach to something. The only problem with the magent method would be if the boat was overturned, and you couldnt get to the magent.
(in reply to Dave trimmer)
       Post #: 14
RE: Rescue boats - 8/10/2006 5:55:01 AM
BlueMonster
Status: offline
I think I'll experiment with a couple things this weekend. I like the idea of circling the dead boat and catching it on something
       Post #: 15
RE: Rescue boats - 8/10/2006 10:29:25 AM
sean22
Status: offline
i have never heard of a retreval boat before i joined this site lol .. i have been using a $70 inflatable raft 1 person with 2 oars and is a hassle to take down the river and pump up then pack it up when im leaving .I think i might try and make a retreval boat out of another cheapo ebay job and rig some kind of setup thanks for the ideas. I really like your boat perfect for the job
