Why are my glow plugs burning out?
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler for Saito
Seller:  RC Specialties
Details:   $69.95   |  10/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Why are my glow plugs burning out?
Page: [1]
Login
Why are my glow plugs burning out? - 2/3/2002 7:07:53 AM
helinsd
Status: offline
Been having fun w/all kinds of glow eng. for 15 yrs. and have never had this prob. Does not matter if the plug is new or used, after a perfect performance run, the plug coil is broken, after just one tank of gas! I am using OS #8 and a remote glow mount, could it be the remote setup is shorting out some how? or is it an eng. prob. Somebody out there must know, thanks.
       Post #: 1
Re: Why are my glow plugs burning out? - 2/3/2002 7:48:08 AM
Ed
Status: offline
[QUOTE]Originally posted by helinsd
after a perfect performance run, the plug coil is broken, after just one tank of gas! I am using OS #8 and a remote glow mount, could it be the remote setup is shorting out some how? or is it an eng. prob. . [/QUOTE]
A lot of people are going to suggest that you are running it too lean. Just make sure that you back off 300 to 500 RPM on the rich side after you peak it. Never take off with the engine "Peaked".
A couple of other things: Are you using a shock absorbing mount ? Depending on the engines attitude, these can sometimes shake a glow plug element to peices.
Also, after starting your engine, be sure to remove your glow heater before you run it up to the high range. Leaving the heater in place, and running your engine up to high, is a quick way to cook plugs.
Let us know what happens. - Jim
< Message edited by GeeBeeJim-RCU -- Feb 3 2002 3:02AM >
(in reply to helinsd)
       Post #: 2
Another thing... - 2/3/2002 8:18:23 AM
ChuckAuger
Status: offline
Is that your engine might be makin' metal inside..this will blow plugs...
And I take that this is a heli engine??
_____________________________
Breaking the Speed of Sound, Straight Down!
       Post #: 3
I'm with you Chuck - 2/3/2002 2:58:29 PM
bob_nj
Status: offline
What engine is it, and what is the history? At the very least take the backplate off and poke your head inside
       Post #: 4
Why are my glow plugs burning out? - 2/3/2002 6:24:47 PM
Flying Cowboy
Status: offline
Most every time an engine of mine started to destroy glow plug, it was a bearing who started to lose its retainer and the small particules were getting to the plug destroying the element.
In that case I just replace the bearings and clean the engine and the plug problem disapear.
Having fun is my only goal.
       Post #: 5
Why are my glow plugs burning out? - 2/4/2002 10:37:40 AM
bobf46
Status: offline
Too high compression will also kill plugs. You can fix this by shimming the head, it dosent take much to reduce the compression. Good luck!!
If it works, dont fix it
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.785RCU4
