RE: Images - Bev & Joel Flying A Trainer
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> RE: Images - Bev & Joel Flying A Trainer
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Images - Bev & Joel Flying A Trainer - 9/3/2006 12:27:11 AM
bkarstien
Status: offline
Bev, thanks for all your help Im sure I will be asking for more down the road. Maybe we can get to fly together someday.
Bob
_____________________________
AMA 869499
(in reply to cjposada)
       Post #: 76
RE: Images - Bev & Joel Flying A Trainer - 9/3/2006 3:59:10 AM
RCKen
Status: online
quote:
ORIGINAL: bkarstien
Bev
Im starting to put my plane together and looking at the directions it does not say what epoxy to use on putting the wings together. I'm not sure what to use the 6 min or the 30 min........What did you use?
Thanks for the the help you have been.
Bob
If you are joining the wings of your plane you should use 30-minute epoxy. First of all 30-minute epoxy makes stronger bonds and will give you a stronger joint. Second, you may find that the 5-6 minutes you have to work with the 5-minute epoxy usually isn't enough to properly get epoxy on the parts, get the wing halves slid together, align the wing halves, and then secure them until the epoxy is completely cured.
I almost never use 5-minute epoxy as I just don't think the joints are as strong as 30 minute (or higher) epoxy. When joining parts that require epoxy you shouldn't get in a hurry and use an epoxy that set quicky just to speed up the assembly process. You'll usually pay for that when the joint fails in flight.
Hope this helps
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to bkarstien)
       Post #: 77
RE: Images - Bev & Joel Flying A Trainer - 9/3/2006 3:53:12 PM
doubledee
Status: offline
RCKen is right, use 30 minute epoxy whenever possible, it is much stronger. The advantage is that you can use less of it, therefore making the build lighter. Don't hurry your build, take your time and do it right. The only thing I use 5 minute epoxy for is fuel proofing the firewall.
Again, take your time, do it right and the airplane will not only last but will fly better too.
Regareds,
doubledee
(in reply to RCKen)
       Post #: 78
RE: Images - Bev & Joel Flying A Trainer - 9/3/2006 6:59:28 PM
PipeMajor
Status: offline
quote:
ORIGINAL: Skyhigh Bev
PipeMajor, Wow, how long has Milissa been flying? We have a control line field out at our airfield, and several men who fly there almost daily. When you say combat, do you mean streamers?
Bev
Bev, I moved from the PacNW to the Twin Cities in '95 so didn't know Milissa. I did know Tony Huber - her uncle. He and Tom Strom used to fly R/C Formula 1 Pylon but got into C/L combat. One of Tom's sons (shown in the photos within the Bladder Grabber link) won the Nationals in AMA Fast Combat as a Junior competitor - flew against and *beat* all the open class fliers some years back.
Yes, in C/L combat they use streamers. You get points for each "cut" on your opponent's streamer, points for each second being airborne and a "kill" ends the match when you cut the string leader between the model and streamer.
(in reply to Skyhigh Bev)
       Post #: 79
RE: Images - Bev & Joel Flying A Trainer - 9/3/2006 8:28:57 PM
Skyhigh Bev
Status: offline
quote:
ORIGINAL: bkarstien
Bob
Bob, Can't wait to see a picture of the finished plane!!! Don't forget the stripes. You'll have to bring the family down here on "vacation" so you can fly at our field. We definitely have warmer winters than New Jersey!!
Bev
Beverly AMA 858545 myspace.com/southerncross27
BCRCA MPPA 332ndRTF
       Post #: 80
RE: Images - Bev & Joel Flying A Trainer - 9/4/2006 1:31:38 AM
Stickbuilder
Status: offline
Bev,
You really should make it to the Summer's End meet at our club. We are in Belleview (US 441/27) right outside the Villages. It will be on the 16th and the 17th. This is a giant scale meet, and I think that you guys would really enjoy it. Look the club info up at www.ocalaflyingmodels.com We would love to have folks from Lauderdale attend.
Bill, AMA 4720
It's easy, just glue all the pieces together, and sand off everything that doesn't look like an airplane.
       Post #: 81
RE: Images - Bev & Joel Flying A Trainer - 9/5/2006 1:31:42 AM
Skyhigh Bev
Status: offline
quote:
ORIGINAL: doubledee
Regareds,
doubledee
Doubledee & RCKen, Seeing as I have both types of epoxy, I will definitely use the 30 minute like you say for all plane builds. I like the idea of the 5 minute for fuel proofing. Not sure which we used when doing the same in the nose area of the sky raider...I do remember that we did fuel proof it though.
Bev
BCRCA MPPA 332ndRTF
(in reply to doubledee)
       Post #: 82
RE: Images - Bev & Joel Flying A Trainer - 9/5/2006 1:40:56 AM
Skyhigh Bev
Status: offline
quote:
ORIGINAL: PipeMajor
Bev
PipeMajor, Thanks for the info. Melissa's family sounds quite talented. Hopefully one of these days I will get to see a combat competition. I'll check with our control line fliers to see if they ever practice combat with each other. At least I could see that. I'm not sure when there has been a contest at our field for the control line group...this weekend is another pylon race. (another group of very speedy planes!)
Bev
BCRCA MPPA 332ndRTF
(in reply to PipeMajor)
       Post #: 83
RE: Images - Bev & Joel Flying A Trainer - 9/5/2006 1:48:56 AM
Skyhigh Bev
Status: offline
Bill, I will be sure to spread the word about your fly-in. The Ocala field looks nice. I wouldn't be surprised to find that some of our pilots are going. Don't think I can make it up there this time, but hopefully by the next one I will. Make sure you post pictures of the event on your club web site. I'll be sure to check them out. What sizes and types of planes are you expecting?
Bev
BCRCA MPPA 332ndRTF
(in reply to Stickbuilder)
       Post #: 84
RE: Images - Bev & Joel Flying A Trainer - 9/5/2006 11:08:16 AM
Stickbuilder
Status: offline
Bev
Bev,
It's a giant scale meet. Big ol' planes. all kinds.
Bill, AMA 4720
       Post #: 85
RE: Images - Bev & Joel Flying A Trainer - 9/5/2006 9:02:21 PM
Skyhigh Bev
Status: offline
Bill, Just keep the rain away from your event will ya? I haven't flown in 8 days here because of ours!!! I'm about to lose it big time!!! Have a great time, and I will spread the word.
Bev
BCRCA MPPA 332ndRTF
       Post #: 86
RE: Images - Bev & Joel Flying A Trainer - 9/6/2006 3:10:09 PM
bubbagates
Status: offline
Hey Bev,
I just found this thread. I just got done reading it.
Maybe when I come down in a few weeks, I'll hook you up to the box and get you some stick time and my Yak or my Cap or my Ultimate, Ah the heck with it, we'll do all three.
Bill James
Normal is not something to aspire to, it's something to get away from
       Post #: 87
RE: Images - Bev & Joel Flying A Trainer - 9/7/2006 1:22:08 AM
Skyhigh Bev
Status: offline
Bill, Looking forward to your visit. I think you will really like our field, as well as our pilots. Do you fly with a Futaba or JR radio? I'm Futaba. Since I haven't flown a Cap or a Yak yet, the experience should be great. What size Ultimate do you have? I've only flown Eddie's once. (no take-offs or landings of course) Today the weather was beautiful for the first time in over a week. (I haven't flown in 9 days.) Jim Perdue, a pylon racer and board member of one of the MPPA club re-drilled the setup and redid the linkage for my nose gear today. While he did that, Joel, club trainer for BCRCA put me up on his Stinger....first time for me to fly it. I really love flying all the different types of planes. It helps me get a feel for the sticks quicker than just flying my Sky Raider. Hopefully tomorrow morning will be nice weather as well...I'm itching to get airborne.
Bev
BCRCA MPPA 332ndRTF
(in reply to bubbagates)
       Post #: 88
RE: Images - Bev & Joel Flying A Trainer - 9/7/2006 1:14:28 PM
bubbagates
Status: offline
Bev,
I fly a JR10X but there will be no problem getting you hooked up with Futaba. Which one do you have. I have access to several Futaba radios.
The Yak is the Aeroworks 50cc (red one) the Cap is the Great Planes Performance series 27% (Da50) and the Ultiamte is also the GP-PS. They call it a 1.60 size but if you crunch the numbers it comes out at a 30%. It's one inch bigger all around than Wildhares version, which I had last year. I'm trying to get a Wildhare 33% Edge finished in the next 2 weeks. If that happenes I'll bring it with me
I'll bet you liked the Stinger. I flew one over this past weekend for a maiden and had never flown one before and had a blast with it, but then I have a blast with just about every plane I fly. What did you think about the Ultimate you flew. If it was the 46% it should have been a dream to fly. did get to fly one for 3 flights last year and all I can say is I want one.
Bill James
