wjvail
MS, USA Status: offline
Rod.. Your questions are not out of line. If your goal is just to fly, then buy some fuel and burn some. On the other hand this is a hobby and I, more than most, have integrated fuel, mixing fuel, running fuel, testing different fuels and in general, hobbying with fuel as a big part of my modeling. It has been enormously enjoyable and equally educational. You have a right to enjoy this "subpart" of this hobby as I have and as others do. You have a right to test fuels with more or less oil, nitro, castor, synthetic and find what works for you and to do that, you need to know what your buying. If you wish to include experimenting with fuels as part of your hobby then seek fuels that publish what's in them. If you wish to fly, buy some WildCat/Morgans/Sig/Powermaster/RedMax/Byrons/etc. and fly.... One thing you said that I find alarming is that some fuels are not labeled with their intended use. As I mentioned, I mix a little fuel for the local folks. There is a large difference in the Car fuel, 4-C, 2-C, control line and Heli blends. I would NOT run the 25 car fuel in a heli! The control line stunt fuel would be a very poor choice in a car. The 2-cylcle fuel has too much oil and castor and not enough nitro for optimal 4-cycle performance. You have to know what the fuel was formulated for. If the jug just says "Fuel" and nothing more, I'd recommend keep looking. If on the other hand it says WildCat (or any number of other fuel blenders) 20% Four Stroke fuel you can be sure it will work for your application. Hope this helps. Bill Vail
< Message edited by wjvail -- 8/10/2006 12:32:22 AM >
_____________________________
"Well, Nothing bad can happen now."
