RE: Knight Hauler and Box Trailer build thread
Tower Hobbies
Logged in as Guest
Users viewing this topic: Longhair
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: Knight Hauler and Box Trailer build thread
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Knight Hauler and Box Trailer build thread - 8/10/2006 11:36:15 PM
[]TEX[]
Status: offline
Hey Lunchboxer, guess what? Those red shocks.....friction!
_____________________________
JR Vibe 50 powered by O.S. | 7C FASST | Hatori Perfomance | Curtis Youngblood | Reactor X | CSM RL20 | Let the fun begin!
(in reply to []TEX[])
       Post #: 26
RE: Knight Hauler and Box Trailer build thread - 8/10/2006 11:37:34 PM
Lunchboxer
Status: offline
Do you glue those tires to the aluminum wheels?! Any tip on a clean looking glue job? I think I need to get a finner tip for my CA glue.. (for now, I don't care, those are buggy / truck tires.. so I just splash a bunch on.. do a good job.. )
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
       Post #: 27
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 12:32:23 AM
[]TEX[]
Status: offline
The tires do not get glued to the aluminum rims. Tamiya suggests the plastic wheels be glued, but I chose not to here.
Here's some pics of the wheel assemblies. No quick wheel changes here!
The inner wheel is the plastic wheel from the kit. Once assembled you can't see the inner rim.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to Lunchboxer)
       Post #: 28
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 12:36:48 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: Lunchboxer
I use 100% silicone(clear) instead of CA. No white residue and they are easier to remove when it comes time to change tires.
       Post #: 29
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:20:49 AM
Lunchboxer
Status: offline
Cool.. so you need to get six aluminum wheels then?! Are they identical? Or the front 2 are different?
       Post #: 30
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:23:45 AM
[]TEX[]
Status: offline
Yes, I posted some photos showing the front and rears.
You need 2 pair rear and one pair front.
       Post #: 31
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:26:18 AM
[]TEX[]
Status: offline
Here is the shifting process of the tranny.
In order of the pics: 1st-2nd-3rd
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by TamiyaExperienced -- 8/11/2006 1:27:56 AM >
       Post #: 32
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:31:36 AM
[]TEX[]
Status: offline
Tranny fully encased.
Look for this on the Ford HighLift!
Click for fullsize
Click for fullsize
< Message edited by TamiyaExperienced -- 8/11/2006 1:38:51 AM >
       Post #: 33
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:36:30 AM
Lunchboxer
Status: offline
The F-350 will have an extra transfer case for the 4WD! Should be interesting!!
< Message edited by Lunchboxer -- 8/11/2006 1:37:12 AM >
       Post #: 34
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:40:15 AM
[]TEX[]
Status: offline
I believe it will also have a gear reduction and slipper clutch.
       Post #: 35
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:47:07 AM
Lunchboxer
Status: offline
Slower than the semi?! Wow!
Slipper clutch will not be good for the crawler crowd.. I am sure they will tighten that way up.. In terms of drivetrain weakness, those axles should be pretty strong (metal gears, similar to TLT..) so it will come down to whether the tranny can take the rock crawling torque...
       Post #: 36
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 1:59:06 AM
[]TEX[]
Status: offline
I'm pretty sure the slipper was used to not damage the tranny as it is quite sloppy and any sudden jerks under a heavy load would certainly do some damage. The rigs are on-road only and don't go through much rigor, but I am sure the 350 would. Plus, the tires are quite large adding even more stress to the tranny.
Taken directly from TUSA:
"SLIPPER CLUTCH
Includes slipper clutch as standard part to protect
gears during tough off-road running."
< Message edited by TamiyaExperienced -- 8/11/2006 2:01:58 AM >
       Post #: 37
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 2:25:14 AM
Lunchboxer
Status: offline
Yeah, I read that... should be interesting.. hope they make some improvement on the tranny too.. with ballbearings and all, hopefully there's not that much slop!
Anyway, not trying to hijack your thread.. Time to go back to the semi!!
       Post #: 38
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 5:53:25 AM
secretsg
Status: offline
$$$ is not the issue here.. DX6 has digital trims.. can't work with MFU... Or I'd get one!
The MFU will work with Radios with digital trims as long as they can transmit PPM Signals. The MFU expects PPM
signals for servo and will have problems if you transmit PCM as most computer radios are capable of. Most of the
Futaba line (6EXAS for example) are PCM or PPM selectable and will work great with Tamiya MFU. There is additional
issues with the DX6 as the AR6000 receiver has the fail safe programmed at continous for planes/helis. You'll need
the BR6000 receiver which has failsafe set at hold. DX6 also can't shut down MFU via the transmitter, you'll have to
get a kill switch rigged to one of the spare channels on Ch5 or 6.
There is NO best anything in RC. No one CARES about what is the fastest. Asking same question a million times WON'T help.
       Post #: 39
RE: Knight Hauler and Box Trailer build thread - 8/11/2006 5:56:37 AM
Lunchboxer
