Took CP head apart and now blades are facing WRONG!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Took CP head apart and now blades are facing WRONG!!!
Page: [1]
Login
Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 2:36:19 AM
hutchpba
Status: offline
I just pulled the head off of my cp and replaced the o rings because I had a little wobble...Any how I put it back together and the blades are facing in the wrong direction? It just doesnt seem possible and is probably a easy fix but im lost and frustrated.
Hutch
       Post #: 1
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:03:09 AM
Psikelly
Status: offline
Are they symmetrical blades??
_____________________________
NO I did not just crash!! Im making it flop around on the ground like that on purpose. Its a new stunt.
(in reply to hutchpba)
       Post #: 2
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:11:27 AM
hutchpba
Status: offline
Nope...Standard flat bottom woodies.....The round part of the blade is facing the direction of rotation...Can some one post a picture of what it is suppose to look like as I just might be craZY!
hutch
(in reply to Psikelly)
       Post #: 3
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:12:17 AM
Psikelly
Status: offline
oops... The best way to test this is to disconnect all linkages etc from the main hub. Taking off the flybar is helpful but I dont think necessary. If you do remove it then also remove that top screw. Then slide the top of the hub up and down on the shaft. Youll immediately notice if its too sticky
       Post #: 4
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:14:50 AM
Psikelly
Status: offline
lol wrong post in the wrong thread Any way...If youre blades rotate to the right when you throttle up Then the rounded part should be facing that way.. so the rounded part of the blade will be facing to the right..with rotation
       Post #: 5
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:17:30 AM
hutchpba
Status: offline
Well I guess I was just crazy...Cause thats how the are...Just didnt look right to me...Thanks
       Post #: 6
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:19:10 AM
Psikelly
Status: offline
And dont worry youre not the only 1 that thought that. Ive done it too. Couldve sworn they were on the other way B4 I started. It was like an hour of "these look backward,,,,No they dont,,,yes they do...no they dont...Yah they do I think its whats called a brain freeze lol
       Post #: 7
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 3:21:26 AM
hutchpba
Status: offline
Yup thats exactley how I felt...Thanks again
       Post #: 8
RE: Took CP head apart and now blades are facing WRONG!!! - 8/10/2006 4:06:42 AM
Gonwee
Status: offline
If you not sure how they should be then look at a picture online. Flat bottom blades should have the flat part on the bottom. I don't think you can put them on wrong as long as the flat is on the bottom.
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU4
